- 07-28-2012, 04:41 PM
Thread Author #1
Problems with cut and paste
Anybody else with problems cutting and pasting?
I find either it doesn't work or worse, it results in freezes and crashes within chrome
Sent from my SCH-I535 using Tapatalk - 07-30-2012, 07:10 PM
Thread Author #2
Anyone?
Just tried it now, tried to copy and paste from the messaging app to Gmail
copy function was successful but i didn't even get a prompt to paste in gmail despite long holding in the free text field
Sent from my SCH-I535 using Tapatalk - 07-30-2012, 07:13 PM #3
Re: Problems with cut and paste
I always get FCs. Out of curiosity are you using Swype? I'm wondering if their latest (awful) update is part of the problem and I keep forgetting to uninstall and check.
Droid X
Samsung Galaxy S3 - CM10Thanked by: - 07-30-2012, 07:21 PM
Thread Author #4
I'm using Swiftkey 3
I should try it on Swype as I have that installed too
Maybe I'll try it on the stock keyboard and report back - 07-30-2012, 08:42 PM
Thread Author #5
Could not get it to work with the stock keyboard either
Surely I cannot be the only one with this issue?
Tried to cut and paste a text message into tapatalk, fc on attempt 1, no ability to paste on attempt 2
This is so frustrating...
Sent from my SCH-I535 using Tapatalk - 07-30-2012, 09:28 PM #6
Try in the email app if you really want a exercise in anger
Sent from my SCH-I535 using Tapatalk 2Thanked by: - 07-31-2012, 12:02 AM #7
Mine worked fine for weeks then suddenly stopped working. The only solution on the web was a hard reset so I did that and mine is back to normal now. Probably a bug or a bad app install.
Sent from my SCH-I535 using Android Central ForumsThanked by: - 07-31-2012, 02:35 AM #8
I had this exact same issue.
You have 2 options;
1) Factory Restore your device
2) ROOT your device, install ROOT Explorer, navigate to / > data > clipboard, select ALL and delete all, than go into your Settings > Applications Manager > All, look for TestServices, than remove updates/clear data. Reboot and everything should be fine.
I opted for option 2 simply because restoring a device sucks and I wanted to root anyways because I missed AdFree, ROOT Explorer, and could not stand the WIFI Notification.
Essentially what happens is something in your clipboard becomes corrupted by TestServices. You basically have to clean up a mess you did not make.
Thanks appreciated
Sent from my SCH-I535 using Android Central ForumsThanked by 15:+ Show/Hide list of the thanked
- 07-31-2012, 06:17 AM
Thread Author #9
Root is forthcoming then
Thanks to all you guys for the help
The battery life and camera is great on this thing
Beyond that, I find I'm really beginning to miss my Nexus..... - 07-31-2012, 09:39 AM #10
Droid X
Samsung Galaxy S3 - CM10 - 07-31-2012, 06:44 PM
Thread Author #11
Confirmed jaj6503's method #2 works
Thanks a million man
Sent from my SCH-I535 using Tapatalk - 08-07-2012, 07:16 AM #12
Thank you so much jaj6503
It really work. My s3 is my first android phone and my first time to root for this. Rooting is so easy. 0.01% risk only. All i read from forums just exaggerated that rooting is hard. Now i'm searching things i could do more now. Thanks again - 08-07-2012, 07:25 AM #13
Droid X
Samsung Galaxy S3 - CM10 - 08-20-2012, 11:54 AM #14
- 08-20-2012, 12:53 PM #15
Chaps, see this link http://forums.androidcentral.com/sam...ml#post2091079
- 08-20-2012, 01:16 PM #16
- 08-27-2012, 10:55 AM #17
I couldn't find a clipboard in data. I searched for it and couldn't find it any where else. Tried just clearing test services. Nothing happened after the reboot.
- 08-27-2012, 11:25 AM #18
- 08-28-2012, 01:44 AM #19
- 08-28-2012, 06:44 AM #20
- 08-29-2012, 01:55 AM #21
I just want to say that I am having this issue as well. Phone was working fine and then it doesn't let me copy or paste in any app anymore.
I'm also having separate issue where my phone is started to freeze up and be non-responsive with an error coming from "Test Services"....my guess is that it's probably part of the same problem.
Sent from my SCH-I535 using Android Central Forums - 08-29-2012, 06:40 AM #22
It is.
Thanked by: - 09-06-2012, 07:50 AM #23
Hi I'm new also and my tab2 7 lost the copy paste feature I think after the ics4.04 update... or after installing games
Been trying to do option 2 but I can not find the CLIPBOARD. I looked everywhere and even tried different root explorers/viewers. I can find the DATA folder but it is blank no CLIPBOARD
I did find the TESTServices and cleared the data but ther is no option to remove updates.
REstart my tab2 several times but still no copy paste option
Getting frustrated now and I want to do a factory start.... I don't even know how hahaha - 09-07-2012, 06:44 PM #24
- 09-08-2012, 02:18 PM #25
Reply
