Today I managed to hook my GS3 to my Droid X car dock. I connected the power cable directly to the phone and turned car mode on and opened Google map.
The screen dimmed after 1 minutes, this is my setting when to turn the screen off, and shortly after it turned off. I changed several settings (no auto brightness, no power saving, removed display power saving option, eye detection on/off) with no luck.
On my Droid X, as long as you have the phone on the dock and power is feeding the phone and car dock icon is on then the screen never turns off when you have it on Good map.
Is this is a normal Samsung phone behavior, screen always turns off except when you have navigation on?
Any solution?
Any solution?
