Results 1 to 6 of 6
    Question Better battery life on 4G than on 3G?
    Has anybody else noticed this with their phones? My 4G signal is 5 bars vs 3G at 3 bars when I'm at home or work. I'm noticing that perhaps my 4G battery life is a little better, possibly due to the better signal. Does it make sense that the 4G coverage would actually be better than the 3G coverage?
    If the signals are a primary determinant in battery life, then it makes sense with what I'm seeing. It's not an enormous difference, but I'd say 15% or so better for when the phone is just doing background syncing and whatnot.
  2. #2
    dubge's Avatar
    Posts
    ROM
    Always changing
    Default Re: Better battery life on 4G than on 3G?
    I would guess when on 3g you are looking for a 4g signal once and a while causing a little more battery drain
    Samsung Galaxy Note 2
    But I'm using Phone Info to manually change from 3G only to 4G. So when I'm on 3G it shouldn't be looking for a 4G signal.
  4. #4
    I noticed this last time I traveled. I was in an area that had no 4g and in went through battery much faster than I do here at home. And was actually using it less as I was in meetings the whole trip. I found it odd but seems to make sense if it is constantly searching for 4g it would drain a lot faster.
    Sent from my SCH-I535 using Android Central Forums
  5. #5
    Serial Fordicator's Avatar
    Posts
    ROM
    das bamf 3.0 rc4
    I wonder if it has to do with svolte. EVDO can't do it without an extra radio so I guess the S3 runs the extra radio when in 3g. Just a theory
  6. #6
    murphious's Avatar
    Posts
    ROM
    3.0.8-gda6252
    I am no expert on the matter but i thought of putting my thoughts in.
    The 4G network works so well in buildings and houses because it takes on the characteristics of 2G. It is able to go through building and infrastructure or around objects much more easily than 3G.
    Having used 2G and 3G I can see the noticeable difference. 3G phones make it seem like it is working harder to send and receive these said signals and thus adding to the battery strain. More excessive telecommunication activity...
  1. Better battery life on 4g only vs wifi
    By ojil1999 in forum Droid RAZR
    Last Post: 11-19-2011, 06:32 AM
  2. Tired of battery life, whats it like on root?
    By dasdren09 in forum Verizon Fascinate
    Last Post: 03-21-2011, 11:10 AM
  3. Battery Life with 4G/GPS/WiFi etc ON?
    By ali.fazal in forum Sprint Epic 4G
    Last Post: 10-25-2010, 06:59 PM
  4. Which has better battery life on 4G? Epic or EVo
    By StDevious in forum Sprint Epic 4G
    Last Post: 08-31-2010, 07:27 AM
  5. Replies: 25
    Last Post: 06-24-2010, 01:34 AM
