Results 1 to 11 of 11
Like Tree1Likes
  • 1 Post By jneusch
    Question Wi-Fi Problem with SG SIII Verizon
    To get the Wi Fi to search for locations, under settings, I have to turn off the Wi Fi and then turn it on again before it will successfully scan for locations. Why do I have to keep turning it on and off to make it work?
    Thanks.
    EH
  2. #2
    Default Re: Wi-Fi Problem with SG SIII Verizon
    Quote Originally Posted by EH6624 View Post
    Thanks.
    EH
    Im slightly confused on what you mean. To get locations for what exactly and do you mean you have to fully turn off wifi and then turn it back on?
  3. #3
    sparesr4sissies's Avatar
    Posts
    ROM
    CM10
    I think OP is talking about available networks not automatically showing up. I like to use a 3rd party app, such as Wifi Manager to be able to select a Wifi network at any time. Something like this may solve your problem.
  4. #4
    I know what the OP means. Over the last couple weeks my home wifi will sometimes not connect. I have to disable wifi, re-enable and it connects fine. It won't connect no matter how many times I click it. If I try to scan it will be gone. It never used to behave this way.
    Samsung Galaxy S4 - AT&T
    Samsung Galaxy Note 10.1 LTE - VZ
    Galaxy Note 8
    Apple iPad3 - 64GB LTE
    Hatren likes this.
  5. #5
    Mine does same thing, obviously a minor bug but still annoying . Just disable and then turn back on and its fine.
  6. #6
    nbdiver's Avatar
    Posts
    Global Posts
    45 Global Posts
    I had this same problem on my first phone but haven't noticed it yet on my new 32gb SIII. What I do notice now is my Wi-Fi turns off by itself sometime during the night. When I wake up every morning I have to turn it back on. Anyone else experience this? I also notice both of my SIII's don't get very good wi-Fi reception. My 32gb is better than my first phone but not by much.
    Sent from my SCH-I535 using Android Central Forums
  7. #7
    jonblaze's Avatar
    Posts
    Global Posts
    76 Global Posts
    Had the problem with it not picking up my home wireless network. I had to go into manage networks, delete everything in there, rescan and it picked up all the available networks like it should. For some reason the networks that were in there wouldn't allow it to scan for new ones.
  8. #8
    PamelaBB's Avatar
    Posts
    Global Posts
    149 Global Posts
    I have had this issue as well, I cannot connect to a network unless I turn wifi off and on again, it's been going on for a while a bit annoying.
    Sent from my SCH-I535 using Tapatalk 2
  9. #9
    I recently switched to Verizon from Sprint. The service while not home is amazing, while I am home though I use wifi. CONSTANTLY having to turn off wifi and use 4G to load Web pages. What the heck is wrong with the wifi radio in this phone. While on wifi I get no Internet connection, website may be offline or had moved yada yada yada. Any fixes out there? 3rd party or from Samsung?
  10. #10
    Quote Originally Posted by jneusch View Post
    I've recently noticed mine is doing the same thing. Interesting. Not a big deal and more annoying than anything else. I wonder why it's doing this all of a sudden?
  11. #11
    oldAGE's Avatar
    Posts
    Global Posts
    154 Global Posts
    I will add "Yup, me too..." Wasn't a problem for me and I thought "...this is much better than how my Original Galaxy S behaved...." but now it's back to the same ol' same ol'.... Not every time but enough times that it's annoying enough. Oh well... and so it goes.
    AGE
  1. Wi-Fi interfering with 3G reception
    By Evo Longoria in forum HTC EVO 4G
    Last Post: 10-25-2010, 09:16 PM
  2. The Wi-Fi problem
    By MetalPhoenix79 in forum Verizon Droid Incredible
    Last Post: 09-22-2010, 01:16 PM
  3. Skyraider and Wi-Fi problems
    By streetglyden in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 08-22-2010, 01:51 PM
  4. Wi-Fi Problems! Please Help!
    By Basis in forum Motorola Droid
    Last Post: 07-16-2010, 10:37 PM
  5. Wi Fi Problems - How I fixed mine
    By montelli in forum HTC Hero
    Last Post: 10-21-2009, 08:48 PM
