Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By jneusch
    SunYam's Avatar
    Posts
    Global Posts
    22 Global Posts
    Default Battery and 4G Issues?
    When I am home using 4G or WiFi everything is fine. I can go to bed around 3am-5am and still have a very good bit of battery life left. But if I'm out and about town I notice my battery drops fast, seems like no matter where I go this happens. It can be 8pm-10pm and my battery will be like at 5% left when I'm out somewhere else. While out I can even use the phone less and it'll still drain fast.
    There's area's around my town that I'm pretty sure doesn't have 4G yet... but seems like in these area's it doesn't just drop to 3G it either shows 1X or nothing at all. Even in one area like this I can use WiFi at girlfriends house and my battery will still drain really fast. Why is this happening?
    Just odd that at my house with 4G or WiFi battery does great and last all day but anywhere else it drains fast.
  2. #2
    Default Re: Battery and 4G Issues?
    Quote Originally Posted by SunYam View Post
    No its not odd really, when your phone is constantly switching signal when you are out and you are in an area with no data service and extremely low service that will kill your battery more than 4G signal. When you are on 1X or no signal at all don't be surprised when your battery drains like crazy. At these times if you know that you are going to be in an area with really spotty service try turning off your data service for time being and you will see your battery stop draining so quick.
  3. #3
    I travel every week and have experienced the same thing. I usually keep my battery topped off in the car while on the road. That way I'm not so worried about it. I am considering a bigger battery though, or maybe the Razr HD Maxx when it comes out.c I haven't decided yet.
    Samsung Galaxy S4 - AT&T
    Samsung Galaxy Note 10.1 LTE - VZ
    Galaxy Note 8
    Apple iPad3 - 64GB LTE
    leroybrute likes this.
  1. ICS update a mess? GPS Issues, 3G/4G issues and battery issues.
    By rebelguy in forum Verizon HTC Rezound
    Last Post: 09-09-2012, 01:04 PM
  2. GB deodexed battery and sync issues..
    By backoffturkey in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 04-06-2011, 07:38 PM
  3. Battery and Display issues...help?
    By mjesenovec in forum Verizon HTC Thunderbolt
    Last Post: 03-20-2011, 01:46 PM
  4. Replies: 10
    Last Post: 08-05-2010, 09:10 AM
  5. Battery and internet issues
    By dlongb13 in forum Motorola Droid
    Last Post: 01-15-2010, 06:25 PM
