Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By HalizDad
    brettxw's Avatar
    Posts
    Global Posts
    830 Global Posts
    Default Draining battery to 0 really help?
    Does draining your battery to zero before charging again actually help? If so how?
    Sent from my SCH-I535 using Android Central Forums
  2. #2
    richardpandy's Avatar
    Posts
    Global Posts
    238 Global Posts
    ROM
    Stock w/ Root
    Default Re: Draining battery to 0 really help?
    From what I have read/been told is that it doesn't matter on Lithium ION batteries. Old batteries it did but newer style batteries don't have a charge history or anything of that sort.
  3. #3
    smitty24's Avatar
    Posts
    Global Posts
    335 Global Posts
    ROM
    AOKP or CM10
    Its supposed to 'condition' them so you more accurate battery readings and supposed life; but as Lakers said ^ there really isnt a need with newer LiON batteries.
  4. #4
    I did this once after I installed a launcher since I felt the battery bar wasn't accurate. But it didn't do anything.
    On laptops, some manuals say to discharge it fully and charge it back up to calibrate the battery every few months or so.
  5. #5
    frankspin's Avatar
    Posts
    ROM
    CleanROM
    I believe Android Central put up a post once pointing to a post on Google+ from someone at Android saying battery conditioning and those apps that wipe bat stats aren't doing much of anything because once you plug your charger in the stats counter resets itself anyway.
  6. #6
    Does nothing.
    There is no memory effect *AND* the smarts in the battery can compute how many full cycles (full cycle is the amount of energy from empty to full) the battery has been through, even with partial charges.
  7. #7
    Not only does it mildly wear out the battery, but you risk the battery voltage going too low, which makes it trash and it will fail to take a charge.
    Generally, keep it charged when you can.
  8. #8
    I'm getting the Mugen 4600mAh extended battery; would it be better to "condition" it per the instructions, or not??? I'm happy to just use it, if it doesn't make any difference; but it is expensive, so don't want to mess it up.
  9. #9
    Sigh :banghead: (paper thrashing noises as he digs for URL)
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
  10. #10
    HalizDad's Avatar
    Posts
    ROM
    Stock for once.
    You have to get rid of the old electricity and add new electricity every now and then or the old electricity may spoil. (lol)
    Treo650 > Pre > Hero > Evo4G > SGS2 > GNex > SGS3.<--seriously great phone
    chadrob30 likes this.
  1. Help to Determine App that is Draining Battery?
    By brettnussb in forum Sprint Nexus S 4G
    Last Post: 08-11-2012, 03:18 PM
  2. phone in purse cause battery to drain?
    By debsdroid in forum Verizon HTC Rezound
    Last Post: 01-24-2012, 12:58 PM
  3. quickest way to drain battery?
    By TheMacs in forum General Help and How To
    Last Post: 01-05-2012, 04:17 PM
  4. Battery drain seems to average around 5% per hour
    By mbranscum in forum AT&T Galaxy S II
    Last Post: 10-31-2011, 10:38 AM
  5. battery draining very bad please help!!!!
    By kingwhite90 in forum Verizon Fascinate
    Last Post: 10-22-2010, 11:01 AM
