Wifi and 3g running at same time
RickG.
Active member
Jul 24, 2012
38
This has been happening a lot lately. It's not the switch off as it stays like this for hours. Nothing else has changed.
Umm, do you have both of them enabled? uploadfromtaptalk1351835704454.jpgIf you do, then if some app is running that requires a mobile data connection, it'll use the mobile data connection even though WiFi is turned on. MMS is the simplest example - I can't think of any other apps that I use that would cause that to happen for long periods of time. The easiest way to find out would be to turn your mobile data connection off (as in the screenshot) - whichever app starts complaining is the culprit. Or if you notice that something isn't getting done (syncing with Facebook or whatever) then you'll find it that way.
If I've totally misunderstood what's happening then I apologize - perhaps a little more information?
Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
I do have them both enabled, bit I should be able to though. Thats why the handoff is important. I haven't added any new apps that I can think of, and wasn't using mms when it happened. I'll try data off next time it happens and see the outcome. Thanks
