1. wowpaw's Avatar
    Updated to JB this morning and now my auto correct is not working. It'll suggest a word in the area above the keyboard but will not automatically change it to that word.
    Anyone else seeing this? I read over the recent threads about issues/changes and did not see this mentioned. It is getting really annoying having to keep retyping things that I typed wrong
    12-14-2012 04:25 PM
  2. wowpaw's Avatar
    Bump? Am I really the only one with this issue?! (Or am I the only one even using the stock keyboard?!)
    12-14-2012 09:17 PM
  3. Trees's Avatar
    I think the stock keyboard is better in Jellybean compared to ICS. I used it for a few hours today before reinstalling SwiftKey 3 that I had prior to a Factory Reset before the Jellybean update.
    12-14-2012 09:22 PM
  4. mgloss's Avatar
    I am experiencing the same problem and it's driving me nuts. Hate it!
    Sent from my SCH-I535 using Android Central Forums
    12-14-2012 11:02 PM
  5. paintdrinkingpete's Avatar
    Swiftkey Flow Beta is available!
    12-14-2012 11:11 PM
  6. wowpaw's Avatar
    I like the keyboard in JB more too, however that isn't the issue I'm having right now. My auto correct on the stock JB keyboard is not working at all. I'll misspell a word, and instead of replacing it with what the system thinks would be the correct spelling, it just leaves it. I've messed around with the settings and still nothing. I've resetted the settings and re-did them, and again, nothing. Really trying to avoid factory resetting it - and I'm not sure there'd be any other solution since it seems not many people are having this issue.
    12-15-2012 01:10 PM
  7. moralcode's Avatar
    Wowpaw, jelly bean does not have Auto correct on note II or any of the the Samsung devices that I've encountered, it has prediction but not the actual auto correct. I've confirmed this through a different forum not sure what one. All you have to do is download the SwiftKey app. I bought mine for 3.99 or you can use the trial version for one month
    Sent from my Note II on steroids
    12-15-2012 01:13 PM
  8. wowpaw's Avatar
    Wow that's mind boggling that they'd have it on ICS then remove it. Any idea why they did that? I'm on GoKeyboard right now, but will probably purchase Swiftkey in the near future
    12-15-2012 01:17 PM
  9. Trees's Avatar
    Sorry thats happening to you. Although I think the JB version is better than the ICS stock, I still had similar issues with words not autocorrecting, etc. I only had the default keyboard in place long enough to get the phone setup again the way I wanted and then reinstalled SwiftKey 3. Kudos to you for having the patience to stay with the stock keyboard. I'd stay away from a Factory Reset if possible as I don't see the ROI from doing that vs. using a third party keyboard like SwiftKey.
    12-15-2012 03:27 PM
  10. wowpaw's Avatar
    There were many, many, many times where I was THIS close to ditching the stock samsung keyboard lol.. dunno how I stuck with it for so long
    12-15-2012 07:18 PM
  11. Christopher Norris's Avatar
    Having the same problem with my phone. My fat fingers make a lot of mistakes. I'm already looking at other options.
    12-18-2012 06:57 AM
  12. AxlMyk's Avatar
    It seems to me the stock JB keyboard is a version of Swype Beta. Was using Swype before the update to JB.
    I didn't like this new one, so I bought Swiftkey. I noticed Swype Beta is no longer on Google Play.
    12-18-2012 08:21 AM
  13. wowpaw's Avatar
    Swiftkey seems to be the paid route; GoKeyboard the free one.
    12-19-2012 06:58 PM
  14. nolittdroid's Avatar
    Its driving me nuts that it doesn't auto correct!
    Sent from my S3 on ACS
    12-19-2012 07:42 PM
  15. AxlMyk's Avatar
    For $4 it's worth it, to me anyway.
    12-19-2012 09:48 PM
  16. cmslick3's Avatar
    I am being driven nuts by this same issue. I have fat thumbs and they make a lot of mistakes. The ICS keyboard did a great job of correcting them for me. Now that JB is here the keyboard sucks. Smooth move Samsung, way to cripple your stock keyboard. I have an Asus Transformer with JB which dose predictive test with auto correct just fine.
    I guess this is the price to be paid for progress...
    12-19-2012 10:19 PM
  17. wowpaw's Avatar
    Yeah, I went ahead and just bought SwiftKey
    12-23-2012 11:33 PM
  18. clemel1's Avatar
    I have this same issue with my Note II. Anybody have any luck getting autocorrect to work w/ the stock keyboard?
    01-15-2013 04:18 PM
  19. itsdede's Avatar
    i have the same issue in March 2013, anyone solved it?
    its really annoying
    03-09-2013 03:42 PM
  1. Weird key problem with stock Samsung keyboard?
    By remydp in forum Samsung Galaxy S3
    Last Post: 10-23-2012, 03:35 AM
  2. Stock keyboard auto correction turn off.
    By SenseMonkey in forum HTC EVO 3D
    Last Post: 08-02-2012, 01:41 PM
  3. Replies: 1
    Last Post: 09-01-2010, 08:53 PM
  4. Anybody using the Samsung keyboard on the Vibrant?
    By floretbroccoli in forum T-Mobile Vibrant
    Last Post: 08-12-2010, 03:40 PM
  5. Word Sudgest/Auto Correct on Phys. Keyboard Anyone?
    By YoungChrisG in forum Motorola Droid
    Last Post: 12-20-2009, 11:36 AM
