Results 1 to 3 of 3
    Default GS3 lock screen help
    So this is my lock screen on my GS3, I am using widget locker's JellyBean theme. I love that but the problem is it takes away the ability to wake the phone using S voice. What I want to know is if I can get that back (no I don't want to use an app shortcut I want it to be like it was stock). Also does widget locker have a Touchwiz theme you can download that would solve this problem? I really need help, I'm counting on you guys.
  2. #2
    Dog5000's Avatar
    Posts
    Global Posts
    365 Global Posts
    Default Re: GS3 lock screen help
    I was about to start a new thread. My question and issue is slightly different but falls under the general Lock Screen category.
    When I have PIN lock enabled the "Lock screen options" is grayed out and not selectable.
    I followed the tips in this write up How to set lock screen and security options on Galaxy S3 | Android Central when I got the phone earlier this year. Settings and their options have changed now in the Jellybean release. I've tried disabling security of any type, but the option is still grayed out.
    Before I go to another launcher, is there something simple I'm missing to add and tweak the lock screen options?
  3. #3
    Dog5000's Avatar
    Posts
    Global Posts
    365 Global Posts
    Quote Originally Posted by Dog5000 View Post
    Figured it out. Have to enabled Swype in addition to PIN in my case. Now itcan set lock screen shortcuts as expected.
  1. Lock screen help needed.
    By monkeyluis in forum General Help and How To
    Last Post: 08-26-2012, 03:42 PM
  2. Lock screen help
    By JeezyCreezy in forum LG Optimus S
    Last Post: 11-28-2011, 05:49 PM
  3. Lock screen help requested...
    By weirdherald in forum Sprint Photon
    Last Post: 09-14-2011, 10:15 PM
  4. Alarm on Lock Screen Help
    By pittsm in forum AT&T Captivate
    Last Post: 02-09-2011, 08:05 AM
  5. lock screen help
    By syrguy1969 in forum Verizon Droid Incredible
    Last Post: 05-02-2010, 07:52 PM
