1. heggood's Avatar
    Does anyone that has gotten the JB update know if the wifi issue is fixed now?
    12-15-2012 12:07 PM
  2. HalizDad's Avatar
    WHICH WiFi issue? The new version scans constantly looking for places to connect. I suspect that will be a battery drag. You can't even "forget" a network after you connect (hard to do if it's a secured network) as it just picks it up again during the next scan.
    12-15-2012 12:38 PM
  3. heggood's Avatar
    The issue with the wifi continually disconnecting/ reconnecting, theres a long thread on here about it. The answer for me is no.
    12-15-2012 05:58 PM
  4. JWLthief's Avatar
    I can't believe this issue hasn't been resolved yet. Using Wifi at home has been unuseable because of this
    12-21-2012 12:03 AM
  1. How to fix the wifi issue with the
    By tacubano in forum AT&T LG Phoenix/Thrive
    Last Post: 06-22-2012, 06:09 PM
  2. Does GB update fix Wifi Issues?
    By Thehomez in forum Motorola Droid X
    Last Post: 04-26-2011, 07:54 AM
  3. samsung is fixing the lag issue
    By spacecasespiff in forum T-Mobile Vibrant
    Last Post: 08-18-2010, 10:40 AM
  4. How will they fix the volume issue?
    By mattera68 in forum Motorola Droid X
    Last Post: 07-20-2010, 05:04 PM
  5. Replies: 0
    Last Post: 06-23-2010, 04:24 AM
