What would it take to get a S3 working on boost mobile? Is it as simple as putting a SIM in from boost or is there more required?
Printable View
Boost is sprint so they dont use sim cards...you would have to call them to see if u can use the esn you currently have and use it on boost
Sent from my SCH-I535 using Android Central Forums
Actually sprint does use sim cards, you just can't remove them.
It is a bit more complicated than that. If it is something you are really interested in, read this thread and thesr videosQuote:
Originally Posted by nate1dawgg [Only registered and activated users can see links. Click Here To Register...]
Thanks for the links dpham00
