S3 calendar problem
Hi all,
As of last Friday the 14th my calendar has stopped syncing. If I go to Settings/Google/ and then my account, i see a red exclamation mark. The only way i was able to get the calendar to sync is if I install Google Calendar from the play store. Once i install this, syncing starts to work again. However if I uninstall the Google Calendar app, syncing stops working again.
I was thinking it was because Google was removing the sync capabilities for calendar, but didn't think that would affect Android:
[Only registered and activated users can see links. Click Here To Register...]
Is anyone else seeing this? I prefer to use the Samsung calendar app over the Google app.
Thanks.
Re: S3 calendar problem
Performing a search led me here. Yep, I am seeing the exact same thing. The solution is the same - install Google Calendar, GS3 cal now syncs up. Uninstall Google, and the GS3 calendar stops syncing altogether. It's a shame, I actually like the Samsung calendar app - I just don't like having another app installed just to get this one to work.
The issue can be resolved!
Check the samsung developers forum [Only registered and activated users can see links. Click Here To Register...]
