1. robrecht's Avatar
    My first S3 started doing this a few weeks ago so Verizon sent me a replacement S3. It's doing the same thing 'though perhaps not as frequently. 1-2 x per day. Previous phone was probably around 4x a day. If this isn't a common problem with the S3, perhaps this is a software problem?
    Any ideas? Anyone have similar problems?
    12-22-2012 01:27 PM
  2. mlb2305's Avatar
    I had this problem about a month ago but for whatever reason it stopped for the most part. Now my gps is pretty much sucking. My wife's phone has never had either issue.
    Sent from my SCH-I535 using Android Central Forums
    12-22-2012 02:08 PM
  3. jdk2's Avatar
    If you've restored the apps that were on your previous device, then it would seem to be a software issue with one or more apps. If you haven't restored anything, it's probably luck of the draw and you've received another bad phone..
    12-22-2012 03:12 PM
  4. robrecht's Avatar
    Yes, I've restored most of the apps I was using, which is why I'm now exploring this option. Is there a way to do a hard reset without Google Play automatically restoring apps?
    12-24-2012 10:35 AM
  5. jdk2's Avatar
    During the setup, you're given the option of using your Google account to restore your phone. Just uncheck that option.
    12-24-2012 01:49 PM
  6. minnieusa's Avatar
    try a different browser. mine was having issues until i changed the browser from the stock one
    Sent from my AT100 using Android Central Forums
    12-24-2012 09:06 PM
  7. robrecht's Avatar
    Thanks. This problem did arise about the time I went back to using the stock browser. First, I'm going to wait and see if the problem persists with the Jelly Bean version of the stock browser. I just got Jelly Bean yesterday.
    12-25-2012 09:58 AM
  1. Tunein Radio shuts down when screen turns off
    By skipper2 in forum Verizon Fascinate
    Last Post: 01-17-2012, 07:28 PM
  2. Thunderbolt won't turn on after switching battery
    By dizlmonsta in forum General Help and How To
    Last Post: 12-10-2011, 01:23 AM
  3. Replies: 19
    Last Post: 04-06-2011, 06:06 AM
  4. Droid won't turn on after unrooting
    By midwestfx in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 03-29-2010, 12:29 PM
  5. Droid won't turn on
    By trackizmy1 in forum Motorola Droid
    Last Post: 01-18-2010, 02:47 PM
