Results 1 to 7 of 7
- 12-22-2012, 01:27 PM
Thread Author #1
Replacement S3 Also Shuts Down, Won't Turn On Again Without Battery Pull
My first S3 started doing this a few weeks ago so Verizon sent me a replacement S3. It's doing the same thing 'though perhaps not as frequently. 1-2 x per day. Previous phone was probably around 4x a day. If this isn't a common problem with the S3, perhaps this is a software problem?
Any ideas? Anyone have similar problems? - 12-22-2012, 02:08 PM #2
Re: Replacement S3 Also Shuts Down, Won't Turn On Again Without Battery Pull
I had this problem about a month ago but for whatever reason it stopped for the most part. Now my gps is pretty much sucking. My wife's phone has never had either issue.
Sent from my SCH-I535 using Android Central Forums - 12-22-2012, 03:12 PM #3
If you've restored the apps that were on your previous device, then it would seem to be a software issue with one or more apps. If you haven't restored anything, it's probably luck of the draw and you've received another bad phone..
- 12-24-2012, 10:35 AM
Thread Author #4
- 12-24-2012, 01:49 PM #5
During the setup, you're given the option of using your Google account to restore your phone. Just uncheck that option.
- 12-24-2012, 09:06 PM #6
- 12-25-2012, 09:58 AM
Thread Author #7
Tunein Radio shuts down when screen turns off
By skipper2 in forum Verizon FascinateReplies: 11Last Post: 01-17-2012, 07:28 PM -
Thunderbolt won't turn on after switching battery
By dizlmonsta in forum General Help and How ToReplies: 2Last Post: 12-10-2011, 01:23 AM -
Epic shuts off by itself, then won't turn on without Battery pull?
By dfine1966 in forum Sprint Epic 4GReplies: 19Last Post: 04-06-2011, 06:06 AM -
Droid won't turn on after unrooting
By midwestfx in forum Motorola Droid Rooting, ROMs and HacksReplies: 9Last Post: 03-29-2010, 12:29 PM -
Droid won't turn on
By trackizmy1 in forum Motorola DroidReplies: 24Last Post: 01-18-2010, 02:47 PM
Reply
