Results 1 to 13 of 13
- 12-25-2012, 05:36 PM
Thread Author #1
Gold series battery
Hi
I wanny buy a Slim extended Gold series polymer battery for my Verizon galaxy s3.
Anyone has any reviews about this battery? Its priced 23.99 and can use with existing battery cover. It comes with 2850 Mah capacity.
Any reviews, comments about this battery, please let me know.
Sent from my SCH-I535 using Android Central Forums - 12-25-2012, 10:02 PM #2
Re: Gold series battery
Bump.. I'm curious too
Sent from my Nexus 7 using Android Central Forums - 12-26-2012, 12:42 AM #3
- 12-26-2012, 10:20 AM #4
- 12-26-2012, 03:06 PM #5
- 12-26-2012, 03:29 PM #6
- 12-26-2012, 03:33 PM #7
I thought about that, but then thought about my experience with extended batteries on my Blackberrys. While in terms of percentages the added thickness is huge, in absolute terms the thickness of a real extended battery isn't all that much unless you really need those skinny jeans or whatever. It's about as much as another battery stacked on top of the one you have, which is essentially all it is. And I've found the phone LOTs more comfortable with a thicker back. So I bought the Onite 4500mAhr battery for less than what you're paying, WITH a back, and I didn't get no measly 550mAhr more, either
I can do anything I like for as long as I like and I'm OK on battery.
- 12-26-2012, 05:52 PM #8
I just bought the battery. I figured what the hell and worth the shot. Should be here in a few days.
I will post results once I get it.
Sent from my SCH-I535 using Android Central ForumsThanked by: - 12-26-2012, 07:02 PM #9
Most of these cheap batteries overestimate their power. I'd be surprised if it lasts any longer than the original and will probably not be as durable/long lasting.
- 01-31-2013, 07:54 AM
Thread Author #10
Re: 3000 Mah original g3 battery
Friends
Is anyone know where to buy the original 3000 mah battery for my Samsung galaxy s3? I need one without a bulky look..
It's in news for a while but don't know how to place an order for it?
I found one at mobilefun.com for 52.99. Not sure it's the same one I'm looking for..
Please help.. I need it urgently...
Sent from my SCH-I535 using Android Central Forums - 01-31-2013, 11:04 AM #11
You should be able to find them on the Samsung website and most carrier websites if you want the actual Samsung battery. I would check those first and the you might be able to find them also on the android store at Android Central.
Hope it helps.
Sent from my Samsung Galaxy S3 using Android Central Forums - 01-31-2013, 12:45 PM #12
You can buy from right here at AC!
Samsung 2100mAh Standard Battery with NFC for Galaxy S3 - Android Batteries - ShopAndroid - 01-31-2013, 09:54 PM #13
Battery life terrible?
By bilobi in forum T-Mobile G1Replies: 20Last Post: 04-02-2013, 01:48 PM -
Trident Electra series case with integrated extended battery
By iastonish in forum Thunderbolt AccessoriesReplies: 5Last Post: 05-20-2011, 01:49 PM -
My Battery is performing at Gold Medal Standards
By Iceycold in forum Verizon HTC ThunderboltReplies: 10Last Post: 04-05-2011, 02:15 AM -
Seidio 3500 mA battery $49. 99 on Amazon gold box deal
By The Hooded Claw in forum HTC EVO 4GReplies: 9Last Post: 10-13-2010, 06:13 PM -
do all the galaxy s series phones use the same battery?
By XKxRome0ox in forum AT&T CaptivateReplies: 3Last Post: 09-25-2010, 02:55 AM
Reply
