- 12-26-2012, 06:46 PM
Thread Author #1
- 12-26-2012, 10:36 PM #2
Re: Does this battery usage seem normal?
An hour on screen time just at 70% does not seem bad. I'm at 40% right now at 2 1/2 hours screen and 15 1/2 hours since taken off the charger today.
Sent from my SCH-I535 using Android Central Forums
- 12-26-2012, 11:18 PM
Thread Author #3
- 12-26-2012, 11:21 PM
Thread Author #4
- 12-27-2012, 01:45 AM #5
Hi there!! I had many battery issues when I first got my S3...and I think your alright, but could be better,
BUT...your battery is fine, because you have to take into consideration your phone calls.
Just because your screen isn't on doesn't mean your phone isn't burning battery, also, take in consideration, that some points of your day, your phone may hit dead spots and that may drain your battery too!!
In the end, only you can rate your battery.
Hope I helped.
I Am The SuperUser - 12-27-2012, 01:50 AM #6
I see chrome is second to screen time. Are you doing a lot of web browsing? On mobile network or wifi? Browsing on mobile network is harder on the battery than on wifi, so that will give a hit on the battery also.
Sent from my DROID RAZR using Android Central Forums - 12-27-2012, 02:08 AM
Thread Author #7
Does this battery life seem normal?
By mike3000 in forum T-Mobile Galaxy S3Replies: 5Last Post: 08-20-2012, 03:50 AM -
Normal battery usage readings?
By fwarchol in forum HTC EVO 4GReplies: 2Last Post: 03-02-2011, 10:56 AM -
Battery usage says Android system at 32%, is that normal?
By hawaiijedi in forum HTC EVO 4GReplies: 2Last Post: 11-16-2010, 07:42 PM -
does this battery tip still work
By musclehead84 in forum HTC EVO 4GReplies: 1Last Post: 10-26-2010, 01:51 AM -
The battery usage for my android system is 20% is that normal?
By hawaiijedi in forum HTC EVO 4GReplies: 4Last Post: 09-25-2010, 12:40 AM
Reply
