What's the best way to tether VZW Galaxy S3 to a lapt that only has wired ethernet jack?
(it does NOT have USB port, bluetooth, or wireless capability... because it's not a commercially-
available laptop)
Thanks! :)
Printable View
available laptop)
Thanks! :)
I don't think that's possible. The laptop needs to have wifi.
Sent from my SCH-I535 using Tapatalk 2
If you don't mind carrying around some extra hardware you could look for like a wireless bridge unit... Not sure of any model numbers or info since it's been a while since I've needed one... You'll probably need to plug the bridge in to mains power and get an ethernet cord for between the laptop and the bridge but other than that it should work just fine.
Sent from my XT897 using Tapatalk 2
Yeah, your only option is a wireless bridge which will let you get a wifi signal using your ethernet port.
Is the laptop ethernet wired to a wireless router? As in, is the laptop connected to the internet?
If not, you could get a simple WiFi router and plug it in. Then connect the S3 to that WiFi. Then use Airdroid or such to transfer files.
Maybe: Plugable USB 2.0 to 10/100 Fast Ethernet LAN Network RJ45 Adapter
[Only registered and activated users can see links. Click Here To Register...]
That does the opposite of what he needs. He already has an ethernet port but no USB port.Quote:
Originally Posted by SparksGuy [Only registered and activated users can see links. Click Here To Register...]
Dang, just like me to get it BACKWARDS. :p :confused: :-[ Sorry.Quote:
Originally Posted by bjboucher [Only registered and activated users can see links. Click Here To Register...]
SparksGuy
Yep, you just need a wireless ethernet bridge. Several good options out there, just search around. Some of them support Power Over Ethernet, so you won't need to plug into an outlet. It will just take power from the ethernet port on your notebook.
