Results 1 to 9 of 9
    Default What's the best way to tether VZW Galaxy S3 to a lapt that only has wired ethernet jack?(no USB)
    (it does NOT have USB port, bluetooth, or wireless capability... because it's not a commercially-
    available laptop)
    Thanks!
  2. #2
    broadwayblues's Avatar
    Posts
    Global Posts
    496 Global Posts
    ROM
    Stock Rooted, Unlocked
    Default Re: What's the best way to tether VZW Galaxy S3 to a lapt that only has wired ethernet jack?(no USB)
    I don't think that's possible. The laptop needs to have wifi.
    Sent from my SCH-I535 using Tapatalk 2
  3. #3
    CMNDR's Avatar
    Posts
    ROM
    CyanogenMod 10
    If you don't mind carrying around some extra hardware you could look for like a wireless bridge unit... Not sure of any model numbers or info since it's been a while since I've needed one... You'll probably need to plug the bridge in to mains power and get an ethernet cord for between the laptop and the bridge but other than that it should work just fine.
    Sent from my XT897 using Tapatalk 2
  4. #4
    Yeah, your only option is a wireless bridge which will let you get a wifi signal using your ethernet port.
  5. #5
    Is the laptop ethernet wired to a wireless router? As in, is the laptop connected to the internet?
    If not, you could get a simple WiFi router and plug it in. Then connect the S3 to that WiFi. Then use Airdroid or such to transfer files.
  6. #6
    SparksGuy's Avatar
    Posts
    Global Posts
    37 Global Posts
    Maybe: Plugable USB 2.0 to 10/100 Fast Ethernet LAN Network RJ45 Adapter
    www.amazon.com/gp/product/
    SparksGuy
    Iä! Iä! Cthulhu fhtagn!
    GEEK CODE BLOCK available on request.
  7. #7
    Quote Originally Posted by SparksGuy View Post
    That does the opposite of what he needs. He already has an ethernet port but no USB port.
    Thanked by:
  8. #8
    SparksGuy's Avatar
    Posts
    Global Posts
    37 Global Posts
    Quote Originally Posted by bjboucher View Post
    Dang, just like me to get it BACKWARDS. Sorry.
    SparksGuy
  9. #9
    kjjb0204's Avatar
    Posts
    Global Posts
    2,590 Global Posts
    ROM
    CleanRom 5.5
    Yep, you just need a wireless ethernet bridge. Several good options out there, just search around. Some of them support Power Over Ethernet, so you won't need to plug into an outlet. It will just take power from the ethernet port on your notebook.
  1. Replies: 5
    Last Post: 12-16-2010, 02:38 PM
  2. Replies: 1
    Last Post: 11-24-2010, 09:04 PM
  3. What is the best way to do a Phone trade with someone?
    By Biezestreet in forum General Help and How To
    Last Post: 11-16-2010, 09:12 PM
  4. So what is the best way to protect my EVO screen?
    By krisrock in forum EVO Accessories
    Last Post: 08-06-2010, 07:27 PM
  5. What's the best way to get music from your iPod to your EVO?
    By rEVOlution in forum General Help and How To
    Last Post: 06-05-2010, 01:13 PM
