1. goffabear's Avatar
    I upgraded to an s3 from an iPhone 4 in November. I've had to get use to a couple changes, but I really love this phone. Recently I tried calling a friend who also has an s3, but with T-Mobile, while I have Verizon. He says he can hear me perfectly, but his voice sounds very muffled and after ten seconds into the call his voice cuts out more and more until I can't hear him at all. First off, I restarted my phone, which did nothing. I googled my problem and cleared the cache in recovery mode, I heard him fine for about a minute, then the normal problems started reoccurring. I also tried to mess with noise reduction and "my call sound" during a call.
    His phone calls are the only ones with bad quality! I am so frustrated. Please help, thank you in advance
    01-22-2013 03:10 AM
  2. lynnneil's Avatar
    Have you updated the os of your device?
    01-22-2013 05:12 AM
  3. bjboucher's Avatar
    Obviously the problem is on his end if his calls are the only ones you are having problems with. He should be looking for help, not you. It's not your phone, it's his phone or t-mobile's network. I wouldn't mess with your phone trying to fix his issues.
    01-22-2013 05:40 AM
  4. goffabear's Avatar
    Yes my phone has the newest update.
    01-22-2013 06:46 AM
  5. goffabear's Avatar
    Hmm I thought that it might be because I have Verizon and he had T-Mobile, but I was sure that it was my phone since when I rebooted it the problem fixed itself for a minute. I'll have to remind him that his phone is the only one I'm having trouble with. Thank you!
    01-22-2013 06:49 AM
  6. broadwayblues's Avatar
    I've read a couple of threads mentioning the tmobile and verizon call quality issue. I'm pretty sure over on the iPhone forums they pretty much narrowed it down to tmobile's tower problems.
    Sent from my SCH-I535 using Tapatalk 2
    01-22-2013 02:56 PM
  1. Horrible Call quality
    By animosus in forum HTC One S
    Last Post: 05-05-2013, 12:49 AM
  2. Call quality (Static)
    By runner7395 in forum Motorola Droid
    Last Post: 06-06-2010, 11:42 AM
  3. Call quality poll
    By Noseeums in forum Motorola Droid
    Last Post: 12-29-2009, 10:42 AM
  4. question about call quality
    By hvymtlman#AC in forum HTC Droid Eris
    Last Post: 12-21-2009, 01:22 PM
  5. Still having call quality problems
    By bmderuosi in forum Motorola Droid
    Last Post: 12-15-2009, 11:01 PM
