Results 1 to 3 of 3
    Default How do I turn off double press for S voice,hoping it might speed up device
    Sent from my SCH-I535 using Android Central Forums
  2. #2
    Default Re: How do I turn off double press for S voice,hoping it might speed up device
    Go to settings, then application manager, then slide it over to ALL applications. Scroll down til you find S voice then click on it. It will give you two options "force close" or "disable" click disable.
    Now it won't open anymore when you double click the menu button, and it won't be running in the background.
    Just remember after you disable it, it won't be listed in your application manager>all applications alphabetically anymore, it will be all the way down at the very bottom of the list. I disabled mine and went to enable it again and was worried because I couldn't find it anywhere, it was just all the way at the bottom. Same goes for any other apps you disable. You can disable S voice and other apps that are running in the background all the time. But only a select few like All share, S suggest, Color, yahoo news and yahoo finance.
    Those are the ones I've disabled and it's sped my phone up quite a bit, and yahoo news isn't eating my data anymore.
    Hope this helps!
    Current device: Verizon Galaxy S3 SCH-I535
    Recovery: TeamWinRecoveryProject!!
    Current Rom: MOAR v3.0.2>>Morphed to my liking.
    Current Kernel: Lean Kernel v2.3
    "If your killed in the Matrix...You die here..?"
  3. #3
    bsannes's Avatar
    Posts
    ROM
    CleanRom 2.5
    Also if you just want to turn of the home double tap the home button to launch s-voice but still want to have s-voice to use. Then go in to the s-voice app and press menu go into settings and there is an option for s-voice to launch with the double press, just uncheck it.
  1. how do u turn off auto fill for email username
    By stinnett35 in forum Droid Bionic
    Last Post: 07-20-2012, 09:56 PM
  2. How do I turn off sound notifications for certain things?
    By different2une in forum AT&T ATRIX
    Last Post: 03-02-2011, 03:58 PM
  3. how do i turn off mics for video recording?
    By greenmtnsrider in forum Motorola Droid X
    Last Post: 10-18-2010, 03:00 PM
  4. How do I turn off the Sound for bootup???
    By luniboy26 in forum myTouch 3G Slide
    Last Post: 07-25-2010, 11:01 AM
  5. How Do I? Turn off startup animation, or at least mute it?
    By fmichigan in forum AT&T Captivate
    Last Post: 07-22-2010, 06:19 AM
