The Samsung Galaxy III with Verizon (same with any Samsung on Verizon) won't allow you to release the second party once you merged 2 calls. It also won't allow you to initiate another 3-way call, even if one of the people in your conference hung up and you're only connected to one person.
Once you merged 2 calls, your only option is to end the call which will end both calls.
Samsung on AT&T and TMobile do have the option very easily on-screen.
Though in many forums people suggest its a CDMA versus GSM issue, its not, as all Verizon 4G phones are on the CDMA network and it can be done on other brands like Motorola,
(Tho it's not an on-screen quick option on the Motorola, do the following after you merged the 2 calls: click home, people/contacts, tiny phone icon at the bottom, and then the green phone icon, which disconnects second party without ending the entire call and you can then even initiate another 3-way call). On any Samsung with Verizon, this option wont work.
I've read somewhere it can be done by doing the following:
"Root your phone and flash cm9 or 10, The dialer on this rom will allow it"
(I'm not even sure if he meant i would stil need a special dialer or once its rooted the phones dialer will let me hang up the second party and/or make another conference call)
Has anyone tried solving this problem with rooting successfully? (or any other method)
