1. Androidprodigy's Avatar
    My battery is charging painfully slow recently, does anyone have a possible solution to this? Thanks
    Sent from my SCH-I535 using Tapatalk 2
    07-23-2013 03:21 PM
  2. meyerweb#CB's Avatar
    07-23-2013 04:10 PM
  3. nyry's Avatar
    99 percent sure its the usb cable that went bad. Try a different usb cable and see if that works
    Sent from my msm8974 using AC Forums mobile app
    07-23-2013 04:41 PM
  4. transistors's Avatar
    don't let the charger plugged in the outlet between charges, sometime, if you let it plugged, it will detect that it's the USB from computer and will limit the charge current
    samsung galaxy -charging issue
    11-18-2013 09:08 AM
  5. DesElms's Avatar
    I'm sorry, but that thread's first two posts -- by that thread's starter (aka, its "original poster" or "OP") -- are just ridiculously wrong and misleading.
    I have, however, added a third post to that thread which sets straight the record; and provides any Samsung Galaxy famly phone user -- particularly a Note II user -- with pretty much everything s/he needs to know about this subject.
    11-19-2013 03:05 PM
  6. Yubaraj Chalise's Avatar
    01-22-2015 04:28 PM
  1. Where is the SD card slot located?
    By Kiersten_Kress in forum Motorola Droid Ultra
    Last Post: 08-27-2015, 10:57 AM
  2. Replies: 11
    Last Post: 07-30-2013, 10:57 PM
  3. Replies: 46
    Last Post: 07-30-2013, 11:53 AM
  4. Best video format for conserving battery life?
    By DevonBoyDave in forum Google Nexus 7 Tablet (2012)
    Last Post: 07-24-2013, 01:39 PM
  5. The buttons have quit working on my Galaxy S3!
    By sweetlyretarded in forum AT&T Galaxy S III
    Last Post: 07-23-2013, 12:19 PM
