Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By CreativTech
    Default S3 Camera Shutter sound
    Has anyone figured out how to turn this sound off? I've looked everywhere I can think of. Thanks!
  2. #2
    Default Re: S3 Camera Shutter sound
    The last I saw (it's been a while back, though) the manufacturers were required to add a camera sound when the shutter activates. Apparently it had something to do with concerns about surreptitious photography -- cell phone photos up skirts and under dressing room doors and such. That might be why you can't shut it off. Loading a custom ROM might allow you to silence or deselect the sound.
    Never really thought about that. Thanks for posting. I thought I was missing something.
  4. #4
    Camera ICS: https://play.google.com/store/apps/d...lynx.cameraics has an option that allows you to turn the shutter sound off.
    Edit: you can also look through Turning camera shutter sound off (Turning camera shutter sound off)
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 4 Beta
  5. #5
    Quote Originally Posted by GSDer View Post
    Yes, a third-party camera app might also work. The app notes for Camera ICS include a disclaimer that silencing the shutter might not work on all devices. The JB camera on my device also does not look like the one in your screenshots. My stock VZW S3 does not have the option to silence the shutter either.
  6. #6
    If you change your ringer setting to mute, it also silences the shutter noise.
    Staying Average Since 1978
    montanaxvi likes this.
  7. #7
    My S3 is set up with factory ROM and I just took a picture to try it out. Did not make a sound and I have not changed any of the camera settings.
  8. #8
    montanaxvi's Avatar
    Posts
    Global Posts
    286 Global Posts
    Carrier
    Stock
    Quote Originally Posted by CreativTech View Post
    This.
    Just turn your volume to mute and it mutes the shutter sound.
    Sent from my SCH-I535 using Tapatalk 2
  9. #9
    Quote Originally Posted by underway99 View Post
    I'm now curious - is your phone running the MF1 build (4.1.2)? What does that final options screen look like - can you post a screenshot that shows the same section?
    Sent from my rooted, debloated, deodexed Sinclair ZX-80 running CM -0.001 using Tapatalk 2
  10. #10
    Yes, I am using MF1. I am not rooted.
  11. #11
    Underway99,
    Oops, I was referring to the Camera ICS https://play.google.com/store/apps/d...lynx.cameraics app.
    Sorry, should have been more specific - the stock Camera app doesn't have a setting to silence the shutter (at least, on Verizon it doesn't).
  12. #12
    Thanks for the clarification. You had me thinking I'd missed something.
  1. Samsung Galaxy S3 Screen flicker then won't start up.
    By manthanvyas in forum Samsung Galaxy S3 I9300
    Last Post: 08-16-2013, 11:59 AM
  2. The camera and video camera of my device are running slowly and badly!
    By Miguel Angel8 in forum Samsung Galaxy Tab 2 10.1
    Last Post: 08-09-2013, 02:23 AM
  3. samsung s3 update cannot view anything in gallery
    By elinen in forum General Help and How To
    Last Post: 08-07-2013, 11:59 AM
  4. Atrix HD camera not able to save lengthy video to gallery
    By natecress in forum AT&T ATRIX HD
    Last Post: 08-07-2013, 11:42 AM
  5. Incoming call camera flash LED notification
    By gn2moab in forum Google Nexus 4
    Last Post: 08-07-2013, 02:03 AM
