Re: Annoyance: Lock screen activated after phone calls
How are you ending your calls? With the 'End' button in the Phone app or with the Power button?...
If the other side ends the call - then it locks
If I end it with the 'End' button - locks.
Key thing is I have encrypted the device. It seems in this case its overall behavior is different and quite unpredictable.
One more thing I just noticed. If I turn on the option "Settings/Lock Screen/Lock instantly with power key" - then it locks even if I just close the lid. Without touching the power button. The moment I close the lid it locks.
This is reeeeeeally annoying. I found no information on any of these issues anywhere.
I expect the device to lock only if the timeout is out or if I lock it explicitly with the 'power' key. It seems Samsung think different.
Versions:
Model: sm-n9005
Android: 4.3
kernel: 3.4.0-2019540
