So I dropped and cracked my phone yet again, this is the Asurion replacement and I am not going to get another one again, moving on to the Note 3 though I really wanted to wait for the S5 but $100 for a new Note 3 I figured I had to go for it.
The phone looks flawless but if you look at the right angle you can see the screen is not cracked, the digitizer is cracked. Normally I crack the screen and not the digitizer and it functions fine. Screen is black, phone turns on, a little buggy though as I can't get anything to work...well I can't see anything but the problem is when I plug in the usb plug so I can save the contents of my internal sd card the computer does not see the phone. I am not sure why a cracked digitizer would do that. Any idea on how I can get the files of the internal memory?
Thanks.
Thanks.
