1. isabel95's Avatar
    I'm using 4.1.2 operating system and have turned off all the battery hogs that I can think of (e.g. display brightness, gps, bluetooth)
    Also looked at running applications and stopped some.
    With hardly any use at all today and starting with 100% charge 6 hours ago I'm down to 57%. That just doesn't seem right.
    I uninstalled Weather Underground which was a constant presence, regularly updating weather information. Thought that might have been the cause, but it hasn't helped the rapid depletion of power.
    Any ideas?
    Isabel
    01-06-2014 12:15 PM
  2. Sailmaker's Avatar
    Have you tried clearing system cache & pulling battery? How long has this been happening? Have you installed any new apps lately? I found upgrading to 4.3 has extended battery somewhat.
    01-06-2014 12:19 PM
  3. HIMAN1998's Avatar
    Any ideas?
    Isabel
    My battery life got better when I went to 4.3, it is available in Settings->About Phone->Software Update.
    01-06-2014 12:19 PM
  4. UJ95x's Avatar
    Any ideas?
    Isabel
    How long has this been happening? It could just be that your battery is getting old, you can buy a new one for around $10 online.
    01-06-2014 12:21 PM
  5. isabel95's Avatar
    I don't even know where the system cache is and I will look for 4.3. Didn't know it was available. Verizon usually updates automatically (hopefully after kinks are worked out).
    Will try to update manually and will try to clear the cache once I found out how to do that and upgrade the operating system + battery pull - first!
    Thanks for the input.
    Isabel
    01-06-2014 12:28 PM
  6. UJ95x's Avatar
    Isabel
    You can wipe the cache in recovery. Turn the phone off,then hold volume up+home+power until you see small blur letters in the top left corner and release it. Then use the volume up and down buttons to navigate and power to select the options.
    01-06-2014 12:31 PM
  7. isabel95's Avatar
    Do I choose "wipe cache partition"?
    01-06-2014 05:47 PM
  8. isabel95's Avatar
    Decided not to choose anything and pressed power button to shut off phone - then I saw "wiping cache now". Good thing I didn't leave it on reset!
    01-06-2014 05:49 PM
  9. UJ95x's Avatar
    Yeah, wiping the cache partition is clearing the system cache
    01-06-2014 05:51 PM
  10. isabel95's Avatar
    Thank you - that plus 4.3 update have not cured the rapid battery drain. Very frustrating.
    01-06-2014 06:18 PM
  11. UJ95x's Avatar
    Hmm, well like I said above, could be an old battery
    01-06-2014 06:25 PM
  12. MrDoh's Avatar
    Yes, I'm also working on battery drain on 4.3. My phone is rooted, so I have frozen a whole lot of unused apps, using Titanium Backup. Also, I've installed greenify and the xposed framework, and have greenified several apps including maps, play service and play store apps, and so on.
    One tool for tracking down apps that use more battery than they should that's useful and easy to use is the "wakelock detector" app, which will tell you what apps are keeping your phone awake (which uses more battery, as opposed to sleeping when idle). You don't need to have your phone rooted for this one, just download it, let it run, and then look at the list of apps that ran when you weren't using your phone. Betterbatterystats will give you more information, but the user interface is less intuitive and more cluttered. It's also a very useful too for tracking down battery usage on your phone, and doesn't require a rooted phone, either.
    I'm also trying not using wifi at home, just to see if that helps. Don't know yet, it might take less battery if the phone isn't switching between wifi and mobile data (have had both enabled), or mobile data alone at home might use more battery. Not sure yet.
    Anyways, I had the battery usage on 4.1.2 down to less than 1% per hour when idle. Hoping to get 4.3 at least below 2% per hour when idle. We'll see.
    Update: My phone's battery usage on idle is just under 2% per hour now. Still looking, would like to get it lower than that.
    01-06-2014 06:30 PM
  1. Note 3: ROM Stock/Battery
    By shlomoreuven in forum Samsung Galaxy Note 3
    Last Post: 01-19-2014, 05:42 AM
  2. Replies: 2
    Last Post: 01-12-2014, 12:47 PM
  3. Galaxy S4 - Off To Phones 4 U To Get My New Battery
    By sjsmith1708 in forum Samsung Galaxy S4
    Last Post: 01-12-2014, 12:26 PM
  4. Need an answer fast. DNA or Nexus 5
    By Velocitydreamer in forum General Help and How To
    Last Post: 01-06-2014, 06:48 PM
  5. please need help about battery
    By predator1o1 in forum Samsung Galaxy S3 Mini
    Last Post: 01-06-2014, 11:29 AM
