1. rxgadget's Avatar
    Every time I put my 4.4.2 KitKat updated GS3 the battery icon had a red x on it. I have tried 4 different cables, chargers, car chargers, different amps from .5, 1, 1.3, and 2. I have even tried using 3 different external battery chargers. My big issue is not the x but it charges like molasses. I used to be able to plug the phone in my car charger and run Maps. Now I loose battery instead of gaining charge of staying the same. This leads to the second issue that Maps and Location / GPS are draining the he** out of the battery. I did a factory reset to see if it would help with this and the drag.. I have half the apps than before and very slow.
    The bottom pic is before factory reset and the top is after factory reset.
    From Tapatalk Pro on my Nexus 7 (2012)
    06-27-2014 12:03 AM
  2. SpookDroid's Avatar
    Have you tried charging the battery with the phone off? Does it charge at the same rate or is it faster? It might be that your battery is near the end of its useful life... If it's the original battery that came with the S3, I wouldn't be suprised. Most of my friends who got the S3 when it came out are already at 50% of whatever the battery lasted at the beginning, and replacing it has improved, so it's not their phones draining faster, it's just their batteries not being able to keep up anymore.
    06-27-2014 12:21 AM
  3. rxgadget's Avatar
    I tried original battery and Seidio extended brand. It seems to be a common issue with more people as I searched other forums.
    The batteries do seem to charge slower. This was not an issue before the 4.4.2 update. It also is not an issue on my Nexus 7 (2012) tablet running KitKat 4.4.4. However who knows what Samsung or Verizon borked.
    06-27-2014 01:28 AM
  4. AxlMyk's Avatar
    Already being discussed.
    Kit kat update charging issue red X
    AC App on SGS3
    06-27-2014 02:10 PM
  5. ColbyJvonBrown's Avatar
    OK I think this should help everyone out with this supposed problem, when its not a problem!! So search what I searched and go to the video and watch the whole video, then go to the battery pics and read what it says, but notice that even when the tablet is charging in the pic it still shows a "red x" is just like the guy said it is the amp at which the tablet or phone is charging is to low so, it is still charging but at a lower and slower rate. And if you are using the charger that came with the tablet OR (S3 this applies to it too) then clean the charging port and charger, if it still shows the x try a different charger for that device that came from another Samsung s3 or tab of the same model!!!!! Hope this helps!! p.s. you probably can't see the "x" in the pictures but its there in every picture.
    Attached Thumbnails Red X on Battery icon when charging-42550.jpg   Red X on Battery icon when charging-42549.jpg   Red X on Battery icon when charging-42548.jpg   Red X on Battery icon when charging-42547.jpg
    06-28-2014 02:22 AM
  6. rxgadget's Avatar
    After more testing and researching this and other forums.. The red x represents low charging. Some phones show this as a notification and apparently instead of words this update shows the x. This means the phone is charging just not at an decent amp. I assume the SG3 is requiring more than .5 mAh. When I try charging with 1.0 mAh or 2.1 mAh there is no x and the phone charges normal or faster (on 2.1). This all includes external batteries..
    06-28-2014 02:33 PM
  7. SpookDroid's Avatar
    I was assuming you were using the original charger! Yeah, half an Amp is not even enough to power your phone with screen on and an app using GPS active.
    Sent from my SM-P600 using AC Forums mobile app
    06-28-2014 10:35 PM
  8. gwhizkids's Avatar
    Can the mods merge this thread with the other one on the same topic?
    06-29-2014 02:58 PM
  9. AxlMyk's Avatar
    Someone will just start a new one anyway.
    AC App on SGS3
    SpookDroid and redcat22 like this.
    06-30-2014 09:03 AM
  10. rxgadget's Avatar
    From the other make post it was mentioned the x may show when charging isn't at the right charge time. Example: if phone is at 85% my red x shows. Using the same charger I get the regular lightning bolt on the battery now that I am at 50%..
    Would have loved to see this notated in Samsung or Verizon's documents. But it's seems we have it solved
    07-01-2014 11:49 PM
  11. Joey Wigwam's Avatar
    I didnt seem to find a conclusive post on this thread about this issue....is it the amps coming from the wall charger? Because ive been using the same charger all the time I had my android tablet. Or is it because the charger or device port isn't clean? seems legit, but did anybody actually resolve this issue?
    04-30-2015 08:20 PM
  12. col2016's Avatar
    01-17-2016 02:07 AM
  1. Multitasking on screen button problem
    By izzy67 in forum Moto G (2013)
    Last Post: 11-13-2014, 11:27 PM
  2. Phone turns off when I boot into the camera
    By JEGuitarist in forum Samsung Galaxy S3
    Last Post: 06-27-2014, 05:07 PM
  3. turning on problem
    Last Post: 06-27-2014, 02:17 AM
