1. inc2fit's Avatar
    I usually don't get furious over stuff, but the battery depletion on my HTC One after 4.4 update is maddening.
    Doesn't make it half a day. The last 27% died in 10 mins. Went from 14% to 1% in literally 1 min!
    Battery settings shows only apps consuming power, shows no hardware or Os consumption.
    Anyone seeing this as bad? Any fixes?
ID:	104000Click image for larger version.
    02-08-2014 06:27 PM
  2. cbreze's Avatar
    The dreaded hard reset is what I would do if I had the issue. My battery is unchanged thankfully. A call/complaint to Verizon and they would tell you the same.
    02-08-2014 07:58 PM
  3. EJT's Avatar
    My battery life actually improved. Dunno.
    02-10-2014 07:35 AM
  4. Premium1's Avatar
    Try factory resetting it. Sometimes that is what needs to be done. If that doesn't work take it into verizon and maybe they will replace it for you.
    02-10-2014 01:03 PM
  5. Wanda's Avatar
    Although I love you're avatar, I disagree. Verizon won't replace it without at least doing some trouble shooting. Step one will probably be a factory reset.
    02-10-2014 07:11 PM
  6. VidJunky's Avatar
    This will be my first day on a charge. This morning was not looking promising as I dropped over 15% in what seemed like a few minutes. Looking at my history it seems to be pretty level but after work will be the real show for me. I already have a plan in place to do a factory reset, as much as I don't want to, but some times you gotta do what you gotta do.
    On a side note inc2fit is that your critter? Are you planning to go back to Gilwell?
    02-11-2014 09:05 AM
  7. thebignewt's Avatar
    My bettery life is as good if not better after updating to 4.4.2 as it was before, which is excellent.
    02-11-2014 12:01 PM
  8. Premium1's Avatar
    Well that is a given. I Didnt mean they would replace it right away. If it continues having issues after they do all their "trouble shooting" then they would replace it
    02-11-2014 06:38 PM
  9. daveandcori's Avatar
    My wife and I are seeing the same thing on our HTC One's since Kit Kat - horrible battery life. I would easily go 8+ hours now I'm lucky to get 3 or 4. In addition, it doesn't connect to 4G quickly or at all after going away from WiFi.
    Stashsmom likes this.
    02-12-2014 01:45 PM
  10. JayBirdHawaii's Avatar
    Agreed .. battery life after the update has gone right down the tubes .. when I go to sleep it's around 80% .. when I wake up in the morning there's a warning on the screen that I'm at 14%. I've even reinstalled the update, deleting all content, did NOT reinstall my apps, disabled BlinkFeed. It's almost like anytime I'm stationary - I feel like I have to plug it in.
    02-12-2014 03:41 PM
  11. cbreze's Avatar
    This may be a bit different from what I've been hearing, but I've noticed that while my battery does seem to be somewhat worse its not really "that" noticible until I hit around 40% left. Then it drains like somebody pulled the bathtub plug. I'm considering the ramifications of a full, back to factory fresh reset. I'd do it in a heartbeat if I knew it would help, but if its for nothing then what a hassle. I don't see a good reason to back up stuff that might be in cahoots with the issue then reinstall a tainted backup, so id be starting from scratch.
    02-13-2014 11:46 PM
  12. bill1171's Avatar
    This seems to be my problem around right around 40/50%. Then two hours later telling me I'm at 4
    02-14-2014 09:28 PM
  13. cbreze's Avatar
    I'm trying out a very minimalistic launcher(sick sky). It seems to be helping noticibly with my power issues. Its definitely not the launcher for everyone, but its kind of growing on me. No frills, small footprint. I'm liking it so far. Plus the better battery life is the plus. YMMV depending on how you use your device, but I've always thought widgets took to much power anyway. I don't see why manufacturers just can't put decent batteries in their devices. One thing for sure for what these damn things cost my next phone will have a decent battery or they can keep it.
    02-14-2014 11:08 PM
  14. joe_fresh's Avatar
    Mine seems to be great, I am a moderate user though. Click image for larger version.
Name:	2014-02-13 02.20.17.jpg
    02-15-2014 08:08 AM
  15. bill1171's Avatar
    Did the htc back up and reset first, same battery life. Did the Power button and vol down factory reset BIG diff 5am yesterday to 8am this morning still had 23% left. moderate use
    02-22-2014 03:52 PM
  1. Replies: 13
    Last Post: 02-10-2014, 08:44 AM
  2. ZTE Valet short battery life due to wifi?
    By HalOfBorg in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 02-09-2014, 08:32 AM
  3. Opera Browser Huge Battery Drain on Samsung Galaxy Note 3
    By nayan350 in forum Samsung Galaxy Note 3
    Last Post: 02-09-2014, 02:46 AM
  4. Battery Doctor Task Killer
    By monsow in forum General Help and How To
    Last Post: 02-08-2014, 04:49 PM
  5. Davlik vs Art battery life
    By cappy718 in forum Moto X (2013)
    Last Post: 02-08-2014, 02:30 PM
