Results 1 to 3 of 3
    Default blinkfeed battery drain
    hi guys, I have noticed that my battery seems to be draining more than usual. I checked and found that blinkfeed is using 25-35%. I never noticed this before and the problem is I NEVER use blinkfeed and I actually have it turned off. am I missing something?
    thanks in advance for the help!
  2. #2
    Default
    Blinkfeed is now the name of the launcher so that's why it shows using the battery like that. it's normal.
  3. #3
    Default Re: blinkfeed battery drain
    Yes, I found out the hard way that they have renamed Sense to "Blinkfeed" when IT ried to disable it and deleted all cache and data for Blink Feed since I don't use it. Then I went back to my home screen and found it was back to the default setup.
    The amount of battery drain for Blinkfeed might be "normal" at 30-45% with this new version of Android, but it has never been that way in the past. If there's not an update that fixes the battery drain, this will be my last HTC phone. I've only had this phone for a little over 7 months and i'm having to do two full charges per day. More if I use it a lot.
  1. Blinkfeed does not auto-update
    Last Post: 02-26-2015, 01:42 AM
  2. SPH-D710 Stuck In Reboot; possible battery issue and/or wet phone
    By BrianWTF in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 07-10-2014, 04:50 PM
  3. help! htc one m7 battery
    By killerjoe in forum HTC One M7
    Last Post: 07-08-2014, 09:24 PM
  4. Screen Drains Battery?
    By Felonies in forum Samsung Galaxy S4
    Last Post: 07-08-2014, 04:07 PM
