Android Forums at AndroidCentral.com >  HTC Android Phones >  Verizon HTC Rezound > Rezound Power and Data cable
Reply
Thread Tools Search this Thread
    Thread Author   #1
Old 12-30-2011, 05:40 PM
Activity: 0/20
Got a Rezound today. Prior to this, I was using an HTC Droid Incredible. Are HTC cables universal, such that I can use my Incredible cables with the Rezound? They look to be the same shaped ends, but there are small differences. I don't want to do any damage by trying to slide a cable into the port that is not made to go in there. Thanks.
  #2
Old 12-30-2011, 05:47 PM
Activity: 3/20
No problems using the power cables from my old D-1. I think you'll be fine.
Sent from my HTC Rezound using Tapatalk
  #3
Old 12-30-2011, 05:58 PM
Banned
Device(s): HTC Rezound - Stock
ROM/Kernel: Perma-rooted and unlocked
Activity: 1/20
Quote:
Yes...Android phones do not use proprietary hardware. They should all be interchangeable.
The weird ends are HDMI MHL ports, which is like a normal Micro-usb plus more. The ports themselves are compatible...I use my Droid 1 charger to charge my Rezound just fine. No adapter needed.
  #4
Old 12-30-2011, 06:04 PM
Device(s): eris,X,T-bolt,rezound
ROM/Kernel: stock
Activity: 2/20
That will work fine.
  #5
Old 12-30-2011, 06:31 PM
Activity: 0/20
Indeed you can use either cable! Relief, I was charging it today and it hit me that the charger looks like a different size so I wouldn't be able to rely on going to someones house and using their charger lol thanks god its the same!
  #6
Old 12-30-2011, 08:45 PM
Device(s): Palm m500 -> Palm TX + Sa
Activity: 3/20
Technically some of the HTC phones use (or at least used to) use a proprietary connector called the HTC ExtUSB, but it is an extension of the mini-usb and you can use standard mini-usb for it.
  #7
Old 12-30-2011, 09:20 PM
Activity: 0/20
Micro USB charging cables for most Android phones are interchangeable. I've used chargers from the original Motorola Droid, Droid X, and Samsung Galaxy Nexus to charge various phones (and a Nook Color) from various manufacturers. If you're ever looking on Amazon for a spare chargers for the office or travel, try searching for other brands, not just your particular phone. I've picked them up on Amazon for as little as $3 and they work perfectly.
  #8
Old 12-30-2011, 10:52 PM
Activity: 0/20
And 500ma is the normal charging power. There are 800ma and 1000ma chargers out there. I'm going back to my optimus forums now.
  #9
Old 12-30-2011, 11:38 PM
Activity: 3/20
Don't waste your money on getting chargers from Amazon or anywhere. Monoprice.com has all sorts of cables at actual prices, not super inflated crap Best Buy and most other retailers charge.
  #10
Old 12-31-2011, 01:50 AM
Activity: 18/20
Quote:
The Rezound comes with a 5V/1A charger. I strongly recommend using one with simlar specs. You can use one at lower amperage, but it will charge slower.
Reply
Search this Thread:
Advanced Search
