Results 1 to 17 of 17
Like Tree2Likes
  • 1 Post By TBolt
  • 1 Post By mlbyanks11
    Default Popping/Cracking sound at beginning of phone call...
    Everytime I make or receive a phone call there is a pop/crack of static just at the very beginning of the phone call...its pretty annoying and almost hurts my ear when it happens ...anyone else experience this?
  2. #2
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Carrier
    Something JB
    Default Re: Popping/Cracking sound at beginning of phone call...
    are you on a completely stock phone or a leak?
    Completely stock
  4. #4
    Default
    are any of your sound settings maxed out?
    Haven't had the issue myself.
    Sent from my ADR6425LVW using Tapatalk 2
  5. #5
    Default
    Are u using a Bluetooth?
    No bluetooth and if I turn the volume down it does make the "pop" less noticeable but its still there and still annoying....wondering if its a software or hardware issue since the rest of the phone call is fine, just happens at the beginning
  7. #7
    Quote Originally Posted by jonvito2 View Post
    Any problem if you leave your general area to make a call so that you're connecting to another tower?
  8. Thread Author  Thread Author    #8
    Quote Originally Posted by TBolt View Post
    Well I honestly don't know...haven't really left town much since I've had this phone (about a month) and when I have, I dont remember any phone calls I made or received.
  9. #9
    road trip!
  10. Thread Author  Thread Author    #10
    Haha...ill have to remember to check it out next time I make a trip
  11. #11
    Wanda's Avatar
    Posts
    Carrier
    HTC One (Verizon) Stock
    Default
    Do it and write it off as"research" lol!
  12. #12
    Default
    lol.
    Honestly, I would ask for a new phone. I would not tell VZW the crackling is only at the beginning of a call.
    Of course, VZW will tell you to do a factory reset first. And, they may ask you to wait for the OTA, too.
    mlbyanks11 likes this.
  13. #13
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Carrier
    Something JB
    You could also have them reset the radios remotely. That helped with my Charge for a short bit...
  14. #14
    lol.
    Yes
    They will
    you need to tell them no you want a new phone. It's possible its a software issue but it sounds a little more hardwareish to me. Almost like when the signal goes through the circuit the circuit overamplifies it causing the popping sound. I would imagine after a while that would eventually start to cause issues with your speaker.
  15. #15
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    Carrier
    Something JB
    The simple answer to the "factory rest" they want you to do is: I already did that. Usually works
  16. #16
    mlbyanks11's Avatar
    Posts
    Carrier
    Stock 2.3.6
    I have the same issue and that you have and I am getting a replacement tomorrow!!..
    TBolt likes this.
  17. Thread Author  Thread Author    #17
    Im going to wait until I get ICS to see if that does anything...I had a hell of a time with "like New" replacements for my droid x and since this phone works perfectly other than this issue, I'm pretty hesitant on replacing it.
