Results 1 to 12 of 12
- 05-13-2012, 12:47 PM
Thread Author #1
Bluetooth/A2DP Problem
Hi all, I did a search but couldn't find anything through this website or through Google's search engine. Here is my issue:
I have a car stereo that supports A2DP streaming from my Rezound. Fortunately, it connects without a problem with the standard battery cover. I can stream regular audio files stored in the phone, connect with Pandora, and stream iHeartRadio. When checking bluetooth on the Rezound, it states that it is connected to phone and media audio.
But, I have recently found that when I have my extended battery cover on the Rezound, I lose the A2DP streaming ability and can only connect for phone calls. When checking bluetooth on the Rezound, it states that it is connected to phone audio (no media).
I do not have access to another device at the moment that supports streaming via A2DP to test. Has anyone else noticed this issue or do I have a bad extended batter cover? Is there a fix other than trying another battery cover? There is a noticeable amount of connections missing on the extended battery cover compared to the standard battery cover.
Thanks. - 05-13-2012, 12:54 PM #2
Hmmm I'll have to see if I can duplicate your problem.
Sent from my ADR6425LVW using Tapatalk 2Yesterday is but a dream, Tomorrow is but a vision, but Today well lived makes every Yesterday a dream of happiness and every Tomorrow a vision of hope. - 05-13-2012, 03:01 PM #3
- 05-13-2012, 03:32 PM
Thread Author #4
I got it from a Verizon store. I believe it is the official HTC one.
- 05-13-2012, 04:21 PM #5Yesterday is but a dream, Tomorrow is but a vision, but Today well lived makes every Yesterday a dream of happiness and every Tomorrow a vision of hope.
- 05-13-2012, 05:04 PM
Thread Author #6
- 05-13-2012, 08:24 PM #7
Re: Bluetooth/A2DP Problem
The bluetooth radios/antennas are not in the cover.
- 05-13-2012, 09:16 PM
Thread Author #8
Then is there any correlation to battery cover and Bluetooth that I am missing?
- 05-13-2012, 09:42 PM #9
None that I can see. Bluetooth works the same with the cover on or off.
- 05-13-2012, 11:33 PM
Thread Author #10
UPDATE:
I tried the extended battery cover on the Rezound just now and for whatever reason, streaming worked. The bluetooth connection stated the same by telling me phone audio and no media audio just like it has been before. Streaming just worked this time. Guess the 4th try is the magic number.
So as cmandd stated, it appears the battery cover has nothing to do with bluetooth. I just don't know why it didn't work before but it works now. I just hope it continues to work.
Thanks everyone. - 05-14-2012, 07:44 AM #11
Try unpairing, then re-pairing the bluetooth.
- 05-14-2012, 08:12 PM
Thread Author #12
I had tried that.
Reply
