Results 1 to 3 of 3
    dnvm's Avatar
    Posts
    Default Serious Help Required
    My Rezound and I are stuck.
    Let me start at the beginning. My Rezound was running “RUU_Vigor_VERIZON_WWE_1.02.605.6” and it was unlocked and rooted. So recently Verizon started forcing this firmware update with no way to stop it that I could find. So I decided to update on my own. I did a Nanoid backup of everything and a Titanium back up of everything. I relocked my phone and I found “RUU-build-4-03-605-2” at Android Police . So I downloaded it and renamed it PH98IMG.zip. Placed it on my SD card and booted into HBOOT were it loaded the new version. It worked so I unlocked my phone and loaded “recovery-ra-vigor-3.15-gnm.img”. I loaded SU from the recovery had it updated at Google Play. Reloaded Titanium rooted and this is where things started to go wrong. No permissions were being given to Titanium. I tried “recovery-ra-vigor-3.14-gnm.img” and I even tried SUSuper but nothing worked. I went into recovery and did a complete Nanoid recovery. Since then I have not been able to get anything to work. I cannot load any older versions. I try to reload “RUU-build-4-03-605-2” but it makes it to #4 system were it gets stuck in a loop of unzipping and updating.
    My very last attempt was to unlock the phone load “recovery-ra-vigor-3.13-gnm.img” go into recovery and do a wipe of everything. Then from XDA-Developers I downloaded the ICS Global Phone Update Firmware and the ICS Global Phone Update. In recovery I used “flash a zip” to update the firmware. I locked the phone and renamed the Phone Update to PH98IMG.zip. Booted into HBOOT and allowed it to update the software. I instantly powered down and renamed “RUU-build-4-03-605-2” to PH98IMG.zip rebooted to HBOOT and it made it to #4 system where it got stuck in the loop.
    When I try just to start the phone it stays on the white HTC screen.
    What can I do to get my phone working again? Please be specific with the steps to take because I am still at the bottom of the learning curve.
    One other question: Can my Nanoid backup recover the data for the internal card so Titanium will be able to recover my programs.
    Thank You SOOOOOOO very much for your help.
  2. #2
    Default Re: Serious Help Required
    Post this in the ROM subforum here and you'll probably get a quicker response and help. I ran into most of this and found my answer here:
    Keep in mind that the instructions are geared for CWM. I use Amon-Ra but it is easy to figure out the steps. Once I flashed the Superuser, I had root. Also, when my Rezound rebooted I let it go all the way into setup before I interrupted anything.
    Good luck
    Thanked by:
    dnvm
    dnvm's Avatar
    Posts
    Thank you for your response and advice as to where to repost this. As of right now I am 98% back up and running thanks to my post at XDA: .
    The only question I have is why when I try to load 4.03-605.2 does it get stuck when it is loading the system image.
    And the really annoying part, after all of this, is that this afternoon I got a message on my screen asking me if I wanted to run the Verizon firmware update (the reason I decided to update my phone in the first place). Luckily this time I had three choice and one of them was REJECT.
