Results 1 to 6 of 6
    Default WiFi Connection issue
    I have been using WiFi without problems other than signal strength. Recently, however, I see that my phone a some point disconnects from my WiFi. So I check and i see that the WiFi spot (my router) is there but it won't connect. I turn WiFi off and on and it connects, but very soon after disconnects and same thing, WiFi spot is there but won't connect. The only solution I have is a restart of my phone. Is there anyone experiencing this issue and have another solution?
  2. #2
    Default Re: WiFi Connection issue
    Make sure the back to your phone is snapped in all the way, htc had a brilliant idea of sticking the antenna in the cover
    Sent from my ADR6425LVW using Android Central Forums
  3. #3
    I see you posted this at 3am... is this when the problems occur (overnight) or during the day as well? The Rezound has a special "sleep" mode at night that turns off WiFi from like midnight until 7am, or something like that.
  4. #4
    jdfrye's Avatar
    Posts
    Global Posts
    144 Global Posts
    if you have the newest update (ICS) there is a advanced setting to maybe try>>> >Menu>settings>wifi>menu>advanced>"best wifi performance/may consume more power"
    The time I posted this has nothing to do the time this happens
    I may have been proven wrong, the time is around the same time since it happened again
  6. #6
    The same thing was happening to me. Under wi-fi advanced there is a setting to "Keep Wi-Fi on during sleep". I changed that to always and the issue doesn't happen anymore.
  1. Droid X WiFi connect issue? Try this...
    By Dural in forum Motorola Droid X
    Last Post: 01-09-2014, 09:33 AM
  2. WiFi connection issues?
    By ellje in forum Verizon Droid Charge
    Last Post: 06-06-2011, 10:23 PM
  3. Xoom having wifi connection issues
    By afolgueira in forum Motorola Xoom
    Last Post: 04-26-2011, 08:43 AM
  4. wifi connection issue?
    By bloodycape77 in forum HTC Droid Eris
    Last Post: 03-13-2011, 09:06 PM
  5. cyanogenmod and wifi connection issues
    By dms76 in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 12-30-2010, 06:26 PM
