Results 1 to 14 of 14
    NHBass39's Avatar
    Posts
    ROM
    Stock rom/rooted
    Default Can unlock my phone ater being on charger..PLEASE HELP
    I have to do a battery pull to get it to unlock anyone know why this would be happening? This has happened to me twice so far.
  2. #2
    major payne's Avatar
    Posts
    Global Posts
    1,675 Global Posts
    ROM
    VernomRez / ICS / CM9
    Default Re: Can unlock my phone ater being on charger..PLEASE HELP
    Sound like the digitzer locked up in that section... I've had that happened a few times but i think i was running Venom when it happened. Yes a battery pull has to be the fix
    Why stop with just flashing a RUU? Move to the next step and install a Rezound ROM. We have many options with many people to ask for help.
    NHBass39's Avatar
    Posts
    ROM
    Stock rom/rooted
    I'm all stock though. Should that still happen every time I pull it off the charger?
  4. #4
    Posts
    Global Posts
    1,675 Global Posts
    ROM
    Quote Originally Posted by NHBass39 View Post
    After the Reset does it work fine until you pull it off the charger? If it does it sounds like a software issue and you know what i say to software issues
  5. #5
    acejavelin's Avatar
    Posts
    ROM
    Stock OTA and Global RUU
    Does this do it on ALL chargers, or just one? It sounds like you have a defective charger that is under/over volting the digitizer, causing it to look up... I have had similar problems with "cheap" brands or chargers that have just failed, the screen becomes unresponsive.
    If it is on multiple chargers... well... ***cough*** Factory Reset ***cough***
    Current Android Phones: HTC Rezound x2 (Personal: ICS 4.3.605.2 Global Mode leak / Work: ICS 3.14.605.12 Official OTA update)
    Current Android Tablet: Nextbook 8 Premium with marxo's N8+ ROM - Revision 1b2 (ICS 4.0.4)
    Previous Android Devices: HTC Droid Incredible 2, Samsung Stratosphere
    Thanked by:
    NHBass39's Avatar
    Posts
    ROM
    Stock rom/rooted
    Quote Originally Posted by Major Payne View Post
    Yes. Thing that bothers me is everytime I charge my phone I will be going through this. GRRRRRR!
    NHBass39's Avatar
    Posts
    ROM
    Stock rom/rooted
    Quote Originally Posted by acejavelin View Post
    Stock HTC charger. I'm going to try my wifes HTC charger and see what happens. I'll post my results. Thanks for the help.
  8. #8
    acejavelin's Avatar
    Posts
    ROM
    Verify the charger is rated at 5V/1A or better, if she has the same phone it shouldn't be a problem, but not all HTC's use the same charger.
    NHBass39's Avatar
    Posts
    ROM
    Stock rom/rooted
    She has the Thunderbolt. Well for a few more weeks till her upgrade.
  10. #10
    android4life007's Avatar
    Posts
    ROM
    Verizon Stock ICS
    LMAO
    -We do not inherit the Earth from our Ancestors, we borrow it from our Children.
  11. Thread Author  Thread Author    #11
    NHBass39's Avatar
    Posts
    ROM
    Stock rom/rooted
    Gonna charge it today will post my results later.
  12. Thread Author  Thread Author    #12
    NHBass39's Avatar
    Posts
    ROM
    Stock rom/rooted
    That fixed it. Thanks for the help.
  13. #13
    acejavelin's Avatar
    Posts
    ROM
    So... What fixed it? Charger was bad???
  14. Thread Author  Thread Author    #14
    NHBass39's Avatar
    Posts
    ROM
    Stock rom/rooted
    Yes. Thanks for the help.
  1. Can web traffic on my phone browser be monitored?
    By Night Train in forum General Help and How To
    Last Post: 10-17-2011, 03:58 PM
  2. Back to stock so I can return my phone.
    By stayqued in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 09-30-2010, 12:20 PM
  3. I hate my phone now. Stuck on thte Verizon logo
    By sgtmack in forum Verizon Fascinate Rooting, ROMs, and Hacks
    Last Post: 09-22-2010, 12:11 AM
  4. i can set my phone back into factory setting if i wanted 2?
    By Androidrookie84 in forum Motorola Droid X
    Last Post: 08-21-2010, 01:14 AM
  5. How do I wake up my phone screen while on a call using BT headset?
    By Android Addict in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-12-2010, 10:22 PM
