Results 1 to 5 of 5
    Unhappy Battery and screen problems
    I got my htc rezound from a friend because he upgraded to the DNA
    And when I first started using it, it only lasted a hour of use and an hour and a half without using it
    I searched YouTube for help and I started deleting or force stoping apps and now
    when I turn it on I have to scroll the notification center down tap on an app , then a pop up says unables to proceed Because com.htc.dg
    And the battery lasts 2 hours now of mild use and I need help bad
  2. #2
    pretext's Avatar
    Posts
    Global Posts
    334 Global Posts
    Default Re: Battery and screen problems
    I would do a factory reset and go from there. That way you'll have a clean slate and can determine if you possibly have a bad battery or not.
    Sent from my Nexus 7 using Tapatalk HD
  3. #3
    I agree with T-REX,then if u find out its the battery,I recommend buying the extended.
    SENT FROM MY S-OFF HTC REZOUND RUNNING VIPERREZ
  4. #4
    Whenever there is a big issue factory reset is the first step
    sent from either my HTC Rezound or my Samsung Galaxy 10.1 tablet
    sent from either my Samsung Galaxy Note2 or my
    Samsung Galaxy Tab 10.1
  5. #5
    acejavelin's Avatar
    Posts
    ROM
    Stock OTA and Global RUU
    I agree as well, factory reset then install , so you can see where the battery is going. If that doesn't seem to make things better, consider a new battery. Note that the Rezound is not really known for battery life, about 2-2.5 hours of screen on time is typical of standard battery.
    Current Android Phones: HTC Rezound x2 (Stock ICS 4.5.605.14 Official OTA update, for now anyway)
    Current Android Tablet: Nextbook 8 Premium with marxo's N8+ ROM - Revision 1b2 (ICS 4.0.4)
    Previous Android Devices: HTC Droid Incredible 2, Samsung Stratosphere
  1. Battery and SD Problems
    By R3deemed in forum Droid RAZR
    Last Post: 10-05-2012, 11:46 AM
  2. battery and usb problem?
    By jenos7 in forum Verizon Galaxy Nexus
    Last Post: 01-04-2012, 01:41 PM
  3. Replies: 8
    Last Post: 07-20-2011, 11:13 AM
  4. Concerns of Battery and Screen PPI?
    By Forgetful in forum Verizon HTC Thunderbolt
    Last Post: 02-01-2011, 09:59 AM
  5. Force Closing, Battery Life and Contacts Problems
    By Shamfajam in forum Sprint Epic 4G
    Last Post: 01-01-2011, 12:43 PM
