Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By acejavelin
  • 1 Post By dpham00
    sweaner's Avatar
    Posts
    Global Posts
    234 Global Posts
    Default New Battery/Heat Problem
    This week my Rezound (Stock, Nova Launcher, extended battery) started getting hot and running through the battery like crazy. Typically I can get through a day with at least 40% battery life left, but not in the last 3 days. No change in my usage. Just now, after no use at all for about 2 hours, the temp was 114.
    I have tried re-starts and a battery pull. Any ideas for what I should try?
  2. #2
    acejavelin's Avatar
    Posts
    ROM
    Stock OTA and Global RUU
    Default Re: New Battery/Heat Problem
    Quote Originally Posted by sweaner View Post
    Install GSAM and use the AppSucker to see what is using the power... this is usually caused by a run-away app holding the wakelock, although sometimes it is hardware, but if it is doing it that quick in a couple hours you should know if its an app and which one.
    Current Android Phones: HTC Rezound x2 (Stock ICS 4.5.605.14 Official OTA update, for now anyway)
    Current Android Tablet: Nextbook 8 Premium with marxo's N8+ ROM - Revision 1b2 (ICS 4.0.4)
    Previous Android Devices: HTC Droid Incredible 2, Samsung Stratosphere
    Thanked by:
    TBolt likes this.
  3. #3
    Also, look at the phone signal in gsam, I noticed a weak signal will drain batteries fast.
    You can also try to clear cache, sometimes it helps.
    Sent from my Verizon Galaxy S3
    "...Galaxy Tab 10.1, Tab 8.9 and Tab 7.7 do not infringe Apple’s Community registered design..." - Excerpt from Apple's website
    Thanked by:
    TBolt likes this.
  4. #4
    How old is the battery? From what I have read these batteries don't go slowly, they all of a sudden plunge.
    Thanked by:
  5. #5
    bserey's Avatar
    Posts
    ROM
    EclipticRez 9
    I had this exact same thing happen but it was soon after i had flashed the global leak. used GSAM and found that it was the android system and the kernal using the battery, tried to go back to a previous leak to no avail (can't go backwards it seems). Tried re-flashing the global again and did 2 factory resets, same results, bad battery life. So I gave up and purchased a wall charger with 2 Laza batteries from Amazon for 20 bucks and now just swap when needed and don't even worry about it. It still bugs me though to not know what has happened. Soon though I plan on working up the nerve and rooting and trying a different rom to see if that helps. Hope it all works out for you and if so post here because I am curious as to what happened to mine also.
    Cheers,
    Bryon
    Thanked by:
    sweaner's Avatar
    Posts
    Global Posts
    234 Global Posts
    Thanks all. The battery is only a few months old. Interestingly, over the past 2 days it seems to be working "normally" again. What percent usage should the kernel be using? Mine is 23%. One thing I have tried is to turn off WiFi, though I have no idea if this has helped. I always thought that less power was used on WiFi.
  1. new battery problems
    By jon-e-o in forum Verizon Fascinate
    Last Post: 06-16-2011, 07:56 PM
  2. New battery problem
    By R3dM0nd in forum Verizon HTC Thunderbolt
    Last Post: 04-15-2011, 08:59 AM
  3. Looking for new battery icons.
    By droid 8172 in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 05-11-2010, 10:26 PM
  4. Heat problems?
    By mrfarinhight in forum HTC Droid Eris
    Last Post: 03-01-2010, 10:35 PM
  5. Battery drainage problem
    By Angelo921 in forum HTC Hero
    Last Post: 12-11-2009, 06:18 PM
