Results 1 to 4 of 4
- 02-06-2013, 01:31 PM
Thread Author #1
S-off problems - -HELP
tried to run the all in on s-off program on my rezound (had a custom rom on it). could not get wire trick to work (p[ropbably cause of custom rom), now cant get past bootloader screen or juopunutbear icon. ---bootloader screen say "tampered" is there anyway to reinstall factory or custom rom from computer/usb...? thanks for any help
- 02-08-2013, 12:12 AM #2
Re: S-off problems - -HELP
Don't worry about tampered sign. It just means you have a custom recovery.
If you can get into the bootloader, Grab the ruu for your version(probably the ota release) and put it on the root of your sd card and allow it to flash in bootloader.
If you cannot get into bootloader, I am not sure what you do, but i know many have had the same problem and gotten out of it.
Sent from my ADR6425LVWHtc Rezound(s-off on ViperRez) ---- Asus Tf300(unlocked on CROMI)
- 02-08-2013, 08:16 AM
Thread Author #3
- 02-08-2013, 09:44 AM #4
Use this guide to flash it:
[How-To] Flash a leaked RUU
You put it on the root of sd car. Rename it. And when you boot to bootloader it will prompt you to flash automatically.
Yes it will rewrite the whole phone. You will have to install a new recovery and everything.
I and if you are still unlocked, which you should be if the soff failed, you will have to re lock before it will work.
virgin mobile wildfire s s-off problems PLEASE HELP!!!
By ogfrier in forum General Help and How ToReplies: 0Last Post: 06-07-2012, 12:28 PM -
By ogfrier in forum HTC Wildfire SReplies: 0Last Post: 06-07-2012, 12:15 PM -
HELP!!! Shut Off Problems!
By deSandot in forum Motorola Droid XReplies: 1Last Post: 09-26-2010, 10:13 PM -
Just Purchased, Problems! Help!
By wwhiterabbitt in forum Samsung MomentReplies: 6Last Post: 12-23-2009, 11:39 PM -
POP email problems. Help
By callmebob in forum Motorola DroidReplies: 5Last Post: 11-18-2009, 09:34 AM
Reply
