TB: Poor battery life post-GB (Dialer?)
biogon
94
9
8
First day with GB today on the Thunderbolt.
I have the HTC 2750 extended battery.
After 9.5 hours off the charger, my battery is at 50% with light usage, all on WiFi, no calls.
This is unusual -- normally by now, I'm at 70% +- 5%.
Curiously though, according to About Phone -> Battery -> Battery Use, my Dialer has used 20% (!) of the battery usage time, but only with 8s of CPU time and 1m 11s of "keep awake".
I love the new Battery Usage chart -- I can see that it's been stuck on 1x for a good chunk of the day (I have horrible reception in my office.)
Anyone else seeing something similar?
No I noticed a big difference myself. Battery life has dropped significantly for me.
Im on stock battery and prior to GB update I was lasting the entire day on my normal usage. Now it dies 2 hours before I leave for work. So its barely lasting over half a day. I leave work at 3 by 1 its dying. And it used to last until 10 or later that night.
I'm with you on this, though not as drastic. I used to get about 10 hrs of up time with medium usage on stock battery, now it feels about 7-8.
When was the last time you calibrated the battery?
My battery life seems better, just going by today. I have the 2750 battery, I leave 4G on all day, but I manually check for updates on stuff like Mail, or Facebook. Anyway, normally, in 5-6 hours of light-to-medium use, I'm down to about 80-85%. Today, with the same usage, I was only down to 95% after 5-6 hours.
It could just be a coincidence, though, that it came after the GB update. It wouldn't be the first time my phone has seemed to have better-than-usual battery life, coming right off of a fresh charge. I'm interested to see how it does tomorrow, since I won't be charging it tonight (why bother, with 95% still left?). If I can get through my 6 hour shift without dipping into the 70s, percent-wise, I'll start believing that GB helps battery life.
menu- settings- call- assisted dialing- uncheck (disable)
I did this this morning, but I'm curious, what exactly is "assisted dialing", anyway? The settings didn't really make it very clear as to what it is.
The dialer is still active, even after disabling. I've had this problem with all 3 of the GB leaks I've installed.
Gee I switched over to the smaller "stock" battery just to see if GB was making a difference in battery life and so far it seems to have worked, I can go all day with the "stock" battery.
I've noticed no difference in battery life, which is disappointing. That is one of the main improvements I was looking for from GB.
I'm at 11:03:51 Up Time, and 02:34:21 Awake time -- with 15% battery life left on my stock battery. It was a lighter than usual day for phone use today, other wise I'd be on my second stock battery by now.
I don't notice a drop in battery life but I do notice that it stays warm a lot longer and more consistenly then froyo. Kind of annoying.
Sent from my ADR6400L using Tapatalk
I'm at 14:23:31 Up Time and 3:04:53 Awake time and the battery is at exactly 50%. I'm not using 4G though. It's an improvement for me as I'd normally be around 20-25% right now.
I think the dialer is a Gingerbread bug. Basically the dialer keeps running in the background after a call, and the only way to stop it is to reboot the phone. And you guys were all begging for this update :D
I had the same problem, and here is what fixed it for me (I am on a rooted build, so ymmv):
Open the People app (contacts)
Menu -> View
under Options, I unchecked everything except for Google. Granted, I only import contacts from Google, so this was not a problem for me. Ever since then, no dialer issues.
Follow this guide, minus step 6 (for rooted users) http://forums.androidcentral.com/th...ttery-after-new-read-only-memory-install.html
Assisted dialing is used for international calls while out of the country. You pick up the phone, and an operator will assist you in making a call. Don't know why it's set at default
Are you sure?
I set assisted dialing on all the time. I was recently in Mexico, Haiti and Jamaica. Also was aboard a cruise ship supporting VZW signals. Each time I got a *free* text message from VZW telling me how to dial from where I was (GPS is cool!) to the U.S. They were all different (i.e. 001+10digit, 010+10digit, 1+10digit). Maybe I remembered some wrong, but, the point....
I have all my numbers entered into my phone with 10 digits (no leading 1s or +s). I made a call from every place to the U.S. Each time all I had to do was to dial using my "People" app just like I always do in the States, and the phone knew exactly how to dial out of where I was, to the States.
No operator assistance was ever required.
-Frank
Are you sure?
-Frank
Well that may be an outdated definition, as I will take your real world experience over mine any day. If it's on I assume it automatically assists in adding the required prefix needed to make the call.
In any case if you're not using the phone internationally, there is no need for it to be enabled. Whether or not this has a significant impact on the "dialer drain" is probably not accurate, but any little bit helps!
Those are pretty good results.
I'm in a strong 4G area and keep it on 4G/WiFi the whole time. It's less hassle for me to simply do a battery swap once a day, than it is to switch back and fourth between 3G/4G 5-9 times a day.
Menu -> View
I do the same thing, doesn't help on the stock builds. Not sure what the difference is?? Would've been nice if that fixed it though.
WhichHomonym
