Beweather issue after GB OTA
Randomhero180
512
29
Since the GB OTA the videos for the Beweather application have looked like they are all static.
Anyone else having this issue that has the GB OTA update?
Uninstall and reinstall BeWeather. I had the same problem and had to do this.
Sent from my ADR6400L using Tapatalk
Did it end to working eventually? I have uninstalled 3 times and still am having the weather animations look all static, like bad tv reception.
After my uninstall/re-install it's worked just find. My has broken after some of the updates. Not every one, but it has happened more than once. I wonder if you have something else that's loading the CPU and/or GPU up.
Not sure, would this be an app?
Are you saying your weather forecast is full of
:cool:
snow?
(sorry, couldn't resist)
Before uninstalling it, did you go into application manager and delete all of its data as well? Perhaps there's some bad data cached somewhere that isn't being deleted on the uninstall?
Yeah just tried again, deleted the whole beweather folder before reinstall.. still all scrambled. Like bad tv reception.
uninstalled 'chesspresso' which was that amazon free app of the day last week sometime. now the weather animations work fine.
Just had the issue again. Uninstalled, reinstall, reboot phone. All is good.
Yeah mine is not totally fixed I guess. Still static every few times I open it. But a reboot does fix it for a bit.
r3dpuk3
