Results 1 to 16 of 16
    Default Apps that help speed up gps lock in
    so it takes like 5 mins for my thunderbolt gps to lock in
    i am going out of town and want my gps to be fast and reliable
    are there any apps that help the gps lock issue
    y original droid locked fasterthan my thunderbolt
    please help.
  2. #2
    yodatom10's Avatar
    Posts
    Global Posts
    2,050 Global Posts
    Carrier
    Stock
    Default
    Quote Originally Posted by tmijares95 View Post
    please help.
    Gps status might help
    Did u apply the last update as it helped the gps work more effective
  3. #3
    Uly
    Uly is offline
    Uly's Avatar
    Posts
    Default Re: Apps that help speed up gps lock in
    I had success with GPS Status. Locks fairly quickly now.
    Quote Originally Posted by yodatom10 View Post
    no it wont download
    it says no data connection when i do
    and i also tried the 1x trick and no luck
    Quote Originally Posted by Uly View Post
    is it Gps status & toolbox?
  6. #6
    yodatom10's Avatar
    Posts
    Global Posts
    2,050 Global Posts
    Carrier
    Stock
    Default
    no it wont download
    If you want u can update your phone using this link the only down side is it will WIPE YOUR DATA.
    http://www.androidpolice.com/2011/07/08/exclusive-download-leaked-1-70-605-0-update-for-the-htc-thunderbolt
  7. #7
    i'm not speaking for everyone, but the update i think made mine worse. before it would take 1-2 minutes but now it takes upwards to 5 minutes for a gps lock.
  8. #8
    +1 to gps status. It fixed same prob for me.
  9. #9
    Unobtanium's Avatar
    Posts
    Global Posts
    534 Global Posts
    Carrier
    Stock
    I use GPS Test, but it's a personal preference. From the menu you can clear and restart the GPS. However, since the latest TB update, I have only had to do it once.
  10. #10
    Is that GPS Status + toolbox? I was referred to GPS FIX and it was of no help to me what so ever. Still without the update and, to tell the truth, loving it.
  11. #11
    Quote Originally Posted by Devils Advocate View Post
    Yes you are correct. I've actually used GPS Fix first but found that to be of no help, then i tried GPS status and toolbox. So far that seems to do the trick.
  12. #12
    Quote Originally Posted by quantumiq View Post
    Although I still get a fairly quick lock, I keep losing all satellites every few seconds for just a second. Not enough to make my GPS useless but it is very annoying!
  13. #13
    satterf's Avatar
    Posts
    Global Posts
    18 Global Posts
    Carrier
    BAMF 1.10
    GPS fix has worked for me
  14. #14
    Both fix and status have not helped me but I have my mobile hotspot without the update so I guess that is a trade off I can deal with.
  15. #15
    vanster's Avatar
    Posts
    Carrier
    Bamf 3.0 rc3
    Gps fix worked for me. Just did the ota on my wifes tb and the gps now locks on immediately.
  16. #16
    GPS status & toolbox didn't work for me but GPS fix worked in 20 seconds
