1. baja141's Avatar
    Did the update to my phone and now the battery draining like crazy. Any suggestion. Need help . Have the extended life . Getting about ten hours.
    07-12-2011 09:27 AM
  2. EricWiz's Avatar
    Yes, shut down, pull the battery, wait 2 minutes, put it back in and boot up.
    That should help. I got the update as soon as it was offered and I am getting great battery life. I went from full charge to 50% after 15 hours on stock battery.
    07-12-2011 09:49 AM
  3. baja141's Avatar
    07-12-2011 09:57 AM
  4. baja141's Avatar
    Thanks did that already still the same way.
    07-12-2011 10:02 AM
  5. yodatom10's Avatar
    Did u install any new apps. Make sure that blockbuster app is not updating in the background
    07-12-2011 10:08 AM
  6. EricWiz's Avatar
    is your auto sync stuck? also, are you in a fringe 4G area? If the first, try disabling auto sync and see if battery life improves. If the second, try forcing cdma only and see if it improves.
    07-12-2011 10:16 AM
