Results 1 to 21 of 21
    zog1977's Avatar
    Posts
    Global Posts
    660 Global Posts
    Default strange problem
    my phone started playing a song last night that i have never heard. It did all night and twice today so far,.
    the only way i get it to stop is to pull down the notification bar.
    i check all my settings, i have no songs attached to ringtones.
    i am at a loss here.
    any suggestions?
  2. #2
    paintdrinkingpete's Avatar
    Posts
    Global Posts
    4,297 Global Posts
    Carrier
    TNTC
    Default Re: strange problem
    That is strange...
    When you say playing a song, you mean via a music player or something like that, or is it a notification of some kind?
    zog1977's Avatar
    Posts
    Global Posts
    660 Global Posts
    there is nothing
    no music player indication, no notification
    it is driving my nuts
  4. #4
    That has happened to me before. Change your default notification and restart your phone.
  5. #5
    Quote Originally Posted by zog1977 View Post
    any suggestions?
    The only thing I can think of is that your phone is haunted with the ghost of Thunderbolts past...ha! That is really strange though.
  6. #6
    yodatom10's Avatar
    Posts
    Global Posts
    2,050 Global Posts
    Carrier
    Stock
    That is strange I would try pulling out your media card and see if if stops.
  7. #7
    It's the Gingerbreadman poltergeist!
    ...but in all seriousness that is wicked strange.
  8. #8
    Is it your alarm?
  9. #9
    spooky
    i'll give a call to Skinner who'll notify Mold and Skull to investigate more about this.
    if you find out. let us know.
  10. #10
    Ed Witles's Avatar
    Posts
    Carrier
    BAMF Forever 1.11 3++
    This happened to me as well.
    I was enjoying SKY.fm (nice 80s tunes) and then heard some 50s. Next, some top 40. It was playing over top of SKY.fm's audio.
    I thought maybe they were having issues but started to recognize the tracks as MP3s I copied to the phone.
    Come to find out, winamp started playing all by itself. I know no one touched it as it sat on my table and we were in the pool.
    Very odd...
  11. Thread Author  Thread Author    #11
    zog1977's Avatar
    Posts
    Global Posts
    660 Global Posts
    it happened 4 times last night while i was sleeping and once this morning. I do not even know what the song is!
    and no, it is not my alarm
  12. #12
    yodatom10's Avatar
    Posts
    Global Posts
    2,050 Global Posts
    Carrier
    Stock
    Default
    Do u have any music streaming apps that could have somehow activated. If you can't get it to stop u might have to do a factory reset. Or call in the ghostbusters :-)
  13. Thread Author  Thread Author    #13
    zog1977's Avatar
    Posts
    Global Posts
    660 Global Posts
    i do have streaming music apps, but it was the same song every time!
  14. #14
    yodatom10's Avatar
    Posts
    Global Posts
    2,050 Global Posts
    Carrier
    Stock
    Default
    Try deleting the music streaming apps. It more then likely is not the cause. But at least we can remove possable causes
  15. #15
    GNUsNotUnix's Avatar
    Posts
    Global Posts
    22 Global Posts
    Carrier
    das BAMF RC4.9
    Here's a thought... Check your battery usage in Settings > About >Battery > Battery use. Anything out of the ordinary showing up in there??
    Also, are you currently rooted?
    Edit: Another thought occurred to me. Maybe check out Settings > Apps > Running Services. Again, anything out of the ordinary running here?
  16. #16
    yodatom10's Avatar
    Posts
    Global Posts
    2,050 Global Posts
    Carrier
    Stock
    Default
    Quote Originally Posted by GNUsNotUnix View Post
    Good idea. If you are rooted it could be a rom issue
  17. Thread Author  Thread Author    #17
    zog1977's Avatar
    Posts
    Global Posts
    660 Global Posts
    not rooted and nothing strange running
  18. #18
    yodatom10's Avatar
    Posts
    Global Posts
    2,050 Global Posts
    Carrier
    Stock
    Default
    U might be looking at a factory reset.I would also download and run lookout and make sure there is not a bad app on your phone causing this
  19. Thread Author  Thread Author    #19
    zog1977's Avatar
    Posts
    Global Posts
    660 Global Posts
    finally trouble shooted it.
    it was a gmail notification from the htc stock email app. it was somehow changed
    it changed it after the last update.
    damn that was aggravating
    thanks for all your suggestions guys.
  20. #20
    yodatom10's Avatar
    Posts
    Global Posts
    2,050 Global Posts
    Carrier
    Stock
    Default
    That would explain the repeated noise at odd times. Glad you got it figured out
  21. #21
    cliffh44's Avatar
    Banned
    Posts
    Crap.... I was waiting for the Insidious explanation.
