Results 1 to 8 of 8
    Default front facing camera problems
    Ever since the MR2 update i have not been able to use my front facing camera. Every time i try to use it to remind myself that the thunderbolt may someday get skype it will act as though it has indeed switched and then continue to use the main camera. I tried clearing the camera apps data and even went into recovery to clear the phones cache and have had no luck. Anyone else experiencing this or know a fix? I'd prefer to not get a new phone since i almost have that stupid coating on the kickstand almost completely off.
  2. #2
    yodatom10's Avatar
    Posts
    Global Posts
    2,030 Global Posts
    ROM
    Stock
    Default
    Quote Originally Posted by bfarr9311 View Post
    Mine has worked fine. If u just want to Get it working a factory reset u should fix it.
    Sent from my Xoom using Tapatalk
    I'm a android know it all with too much time on my hands
    If I've helped you make sure to hit that thanks button
  3. #3
    tropper's Avatar
    Smarty Pants
    Posts
    ROM
    Stock
    Default Re: front facing camera problems
    Just checked mine its working, but I think its broken cuz man that guy is ugly
    Im T rop per and I approve this message
    Thanks for watching = T
  4. #4
    I'm in the same boat as you. It either started with MR2, or GB 3 with 4.9RC. It's frustrating, and I posed the same question elsewhere and did not get any responses that fixed the problem either. Some said I should revert to a different kernal or rom...I'm just waiting it out till the next update...or I might lise patience and go back to an earlier version.
    Oh...you didn't mention if you were rooted or not. I'm rooted, which may make a difference from your problem.
  5. #5
    micwag2's Avatar
    Posts
    Global Posts
    221 Global Posts
    Mine did something similar. Start the camera then click menu scroll down to the bottom and click reset to default. The camera should start working normally then. Go through and reset your preferences.
  6. #6
    I am not rooted and my front camera stopped working. As soon as I open it and go to the front camera the screen goes blank and nothing happens. THEN I can't switch back to the main camera I have to restart my phone! SO annoying. I haven't really paid MUCH attention to it bc it takes such crappy pics but it still should work! I tried to do the thing that Migwag2 suggested and it didn't work
  7. #7
    My front camera works but I've noticed that all the images taken with it are reversed. Anything print wise shows up backwards.
  8. #8
    Quote Originally Posted by Bierich View Post
    Its supposed to do that. You can turn that off but thats how webcams work. If you don't want it to do that, when you are in the front camera mode, push menu and scroll down to the "Mirror" option and turn it off.
