Results 1 to 22 of 22
Like Tree6Likes
  • 1 Post By zero neck
  • 1 Post By Mortiel
  • 2 Post By SpaceHippie
  • 2 Post By FrankXS
    chronic illusionz's Avatar
    Posts
    Global Posts
    133 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default What's the easiest way to take off battery door?
    Soo....I've had this thing since the very first day it was released and I STILL haven't found a reliable way to take the back off, Because of this, that little space at the top looks terrible because I struggle to take it off.
    Yes, it's a good thing because that means it's durable, but jeez! I feel like I'm going to break a finger taking this thing off.
  2. #2
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    Default Re: What's the easiest way to take off battery door?
    Man up
    Haha jk
    Mike_is_Mike likes this.
  3. #3
    OhioG's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I read that using a coin and twisting works. I tried. And it helps.
  4. #4
    Mortiel's Avatar
    Posts
    Global Posts
    612 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    N/A
    Place your thumb on the "4G LTE" logo at the bottom of the battery cover, then dig your index finger into the small tab at the top and pull with your index finger while pushing with your thumb.
    When replacing the cover, be sure that it is securely in place with no gaps along the edge, as it is part of the antenna.
  5. #5
    ambushbug73's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Mortiel View Post
    I've always used the pry and pray method. Thankfully I don't have to remove it often.
  6. #6
    SpaceHippie's Avatar
    Journeyman
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    A
    Default
    Use the simple finger pain and curse method.
    Sent from my ThunderBolt using Tapatalk
  7. #7
    robrecht's Avatar
    Pretty good member
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Insert your thumbnail into the slot at the top and slide it over to the upper left corner of the phone. As you go around the corner, it should start to pop off.
    Thanks, Robrecht
  8. #8
    Mike_is_Mike's Avatar
    Posts
    Global Posts
    1,150 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    That's the way I do it and it seems to work pretty well. You get better and faster at it the more you practice......I swap out batteries once a day, everyday, so I've gotten pretty good at it.
  9. #9
    Posts
    Global Posts
    1,150 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by robrecht View Post
    Thanks, Robrecht
    OUCH!!!!
  10. #10
    Antiseen's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    That way actually works. I've only taken off the cover a handful of times, but I found this way to be the easiest. Doesn't hurt...
  11. #11
    cegabq's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Being female & always having a nail file with me, I carefully use the point to insert & twist.
  12. #12
    ISiddiqui's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I like using the edge of a credit card.
  13. #13
    joshua.worth's Avatar
    Android Guru
    Posts
    Global Posts
    863 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Android 4.1.1 Jelly Belly
    They should've made it a little more practical
  14. #14
    FrankXS's Avatar
    Posts
    Global Posts
    3,645 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Latest OTA Official ROM
    Here's how I do it...
    -Frank
    zero neck and Mortiel like this.
  15. #15
    the one and only M's Avatar
    Posts
    Global Posts
    1,381 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock/CM
    I found myself frustrated for some time with this problem. The trick is to make sure you're not holding the door down while trying to pry it off.
    The battery door is the one design aspect I hate about the hardware.
  16. #16
    Synycalwon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've never had a problem getting the cover off with just a fingernail, which are always kept very short, even when the phone was new. It comes off a little easier now since I usually swap batteries once a day, less when using the extended battery. I just lay the phone face down on a hard surface with a paper towel underneath to protect the screen from getting scratched. Then use my fingernail at the top with my palm near the 4G LTE symbol and pull the cover up. It snaps right up. Doesn’t hurt my nail at all or put any abnormal wear anywhere on the battery cover.
  17. #17
    ggrr8t's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Drop it. Works every time for me...j/k. But back flys off every time i drop it...biut fights me every inch of the way when try 2 rmv it.
  18. #18
    PapaSmurf6768's Avatar
    Themer
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    dasBAMF
    Easiest way to do it is to put your nail in the top left corner then just push a little. Thats my 2 cents
  19. #19
    zero neck's Avatar
    The Ever-Living
    Posts
    Global Posts
    5,097 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    KANG
    Quote Originally Posted by FrankXS View Post
    -Frank
    nice haha
  20. #20
    Mortiel's Avatar
    Posts
    Global Posts
    612 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    N/A
    Quote Originally Posted by Synycalwon View Post
    I've never had a problem getting the cover off with just a fingernail, which are always kept very short, even when the phone was new. It comes off a little easier now since I usually swap batteries once a day, less when using the extended battery. I just lay the phone face down on a hard surface with a paper towel underneath to protect the screen from getting scratched. Then use my fingernail at the top with my palm near the 4G LTE symbol and pull the cover up. It snaps right up. Doesnt hurt my nail at all or put any abnormal wear anywhere on the battery cover.
    Pretty much my method I posted earlier, but one positive note is that after doing it a few times (in my case is was demonstrations for technical support agents), you get good as doing it without having to set it down.
  21. Thread Author  Thread Author    #21
    Posts
    Global Posts
    133 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by the one and only M View Post
    That's the thing. I don't really hate it because it feels sturdy and not cheap.
    But so far, it has just been a pain to get it off without a fight.
  22. #22
    Synycalwon's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Like many things of mechanical nature, it's really about technique. Once you get that down, it's rather simple to pull the battery cover off with just your fingernail. Besides, I'd rather have this "problem" than have no option at all to replace/remove your own battery!!
