Results 1 to 6 of 6
    MOTOX2's Avatar
    Posts
    Global Posts
    173 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Update to 2.10 problem...help?
    Well im in the process of the update but its weird, after it updated the radiois, above the top line
    :MECHA XD SHIP S-ON it says ***LOCKED*** IN Pink. Does this mean anything?
  2. #2
    BayRican's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    CodeName 1.3.3
    Default Re: Update to 2.10 problem...help?
    I don't know what it means but mine said the same thing when I did it. Every thing is perfect on my Thunderbolt . I've got to say I'm finally happy with my TBolt . So I wouldn't worry to much. Somebody on here will know these guys are great .
  3. #3
    ffcody7's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Are you rooted? It could me you need S-OFF for the radio to work. If you are rooted, then what root method did you use?
  4. #4
    Maddog241's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ffcody7 View Post
    From what I have read, it means the Bootloader is locked with s-on. Everything will function fine as a stock unrooted phone. The change in that appearance also means that HTC has added unlocking support for their online unlocking into the bootloader that is included in this build. The online unlocking has not been enabled for the TB yet by HTC.
    Mortiel likes this.
  5. #5
    Cyber Warrior's Avatar
    Robots Will Kill
    Posts
    Global Posts
    11,968 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Nope.. perfectly fine. Phone ships with s-on... bootloader is locked. If you root your phone it unlocks the bootloader giving you s-off.
    MOTOX2's Avatar
    Posts
    Global Posts
    173 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Oh ok, thanks guys.
