Page 1 of 2 12 LastLast
Results 1 to 25 of 26
    biogon's Avatar
    Posts
    Global Posts
    83 Global Posts
    ROM
    Stock
    Default TB: Poor battery life post-GB (Dialer?)
    First day with GB today on the Thunderbolt.
    I have the HTC 2750 extended battery.
    After 9.5 hours off the charger, my battery is at 50% with light usage, all on WiFi, no calls.
    This is unusual -- normally by now, I'm at 70% +- 5%.
    Curiously though, according to About Phone -> Battery -> Battery Use, my Dialer has used 20% (!) of the battery usage time, but only with 8s of CPU time and 1m 11s of "keep awake".
    I love the new Battery Usage chart -- I can see that it's been stuck on 1x for a good chunk of the day (I have horrible reception in my office.)
    Anyone else seeing something similar?
  2. #2
    nate44's Avatar
    Posts
    Global Posts
    813 Global Posts
    ROM
    Synergy
    Default Re: TB: Poor battery life post-GB (Dialer?)
    menu- settings- call- assisted dialing- uncheck (disable)
    Thanked by 4:
  3. #3
    bradbogy's Avatar
    Posts
    Global Posts
    457 Global Posts
    ROM
    Stock
    No I noticed a big difference myself. Battery life has dropped significantly for me.
    Im on stock battery and prior to GB update I was lasting the entire day on my normal usage. Now it dies 2 hours before I leave for work. So its barely lasting over half a day. I leave work at 3 by 1 its dying. And it used to last until 10 or later that night.
  4. #4
    Quote Originally Posted by bradboge View Post
    I'm with you on this, though not as drastic. I used to get about 10 hrs of up time with medium usage on stock battery, now it feels about 7-8.
  5. #5
    nate44's Avatar
    Posts
    Global Posts
    813 Global Posts
    ROM
    Synergy
    When was the last time you calibrated the battery?
  6. #6
    My battery life seems better, just going by today. I have the 2750 battery, I leave 4G on all day, but I manually check for updates on stuff like Mail, or Facebook. Anyway, normally, in 5-6 hours of light-to-medium use, I'm down to about 80-85%. Today, with the same usage, I was only down to 95% after 5-6 hours.
    It could just be a coincidence, though, that it came after the GB update. It wouldn't be the first time my phone has seemed to have better-than-usual battery life, coming right off of a fresh charge. I'm interested to see how it does tomorrow, since I won't be charging it tonight (why bother, with 95% still left?). If I can get through my 6 hour shift without dipping into the 70s, percent-wise, I'll start believing that GB helps battery life.
    Quote Originally Posted by nate44 View Post
    I did this this morning, but I'm curious, what exactly is "assisted dialing", anyway? The settings didn't really make it very clear as to what it is.
  7. #7
    noob question i guess, but what and how do you go about calibrating the battery. this is the first i've heard of this.
  8. #8
    nate44's Avatar
    Posts
    Global Posts
    813 Global Posts
    ROM
    Synergy
    Quote Originally Posted by quantumiq View Post
    Follow this guide, minus step 6 (for rooted users) http://forums.androidcentral.com/thu...y-install.html
    Assisted dialing is used for international calls while out of the country. You pick up the phone, and an operator will assist you in making a call. Don't know why it's set at default
  9. #9
    The dialer is still active, even after disabling. I've had this problem with all 3 of the GB leaks I've installed.
  10. #10
    Default
    Quote Originally Posted by MRW1215 View Post
    Yeah I'm curious what it is as well.
  11. #11
    Gee I switched over to the smaller "stock" battery just to see if GB was making a difference in battery life and so far it seems to have worked, I can go all day with the "stock" battery.
  12. #12
    I've noticed no difference in battery life, which is disappointing. That is one of the main improvements I was looking for from GB.
    I'm at 11:03:51 Up Time, and 02:34:21 Awake time -- with 15% battery life left on my stock battery. It was a lighter than usual day for phone use today, other wise I'd be on my second stock battery by now.
    Sent from my iMac using my fingers and bluetooth keyboard.
  13. #13
    acles003's Avatar
    Posts
    ROM
    Stock
    Default
    I don't notice a drop in battery life but I do notice that it stays warm a lot longer and more consistenly then froyo. Kind of annoying.
    Sent from my ADR6400L using Tapatalk
  14. #14
    Quote Originally Posted by Mike_is_Mike_is View Post
    I'm at 14:23:31 Up Time and 3:04:53 Awake time and the battery is at exactly 50%. I'm not using 4G though. It's an improvement for me as I'd normally be around 20-25% right now.
  15. #15
    PapaSmurf6768's Avatar
    Themer
    Posts
    ROM
    dasBAMF
    I think the dialer is a Gingerbread bug. Basically the dialer keeps running in the background after a call, and the only way to stop it is to reboot the phone. And you guys were all begging for this update
    HTC Thunderbolt
    Favorite ROMs - dasBAMF Forever, SkyRaider Zeus Preview, dasBAMF 1.8.6 Remix
    If I helped ya, click da button!
  16. #16
    I had the same problem, and here is what fixed it for me (I am on a rooted build, so ymmv):
    Open the People app (contacts)
    Menu -> View
    under Options, I unchecked everything except for Google. Granted, I only import contacts from Google, so this was not a problem for me. Ever since then, no dialer issues.
  17. #17
    FrankXS's Avatar
    Posts
    Global Posts
    3,645 Global Posts
    ROM
    Latest OTA Official ROM
    Are you sure?
    I set assisted dialing on all the time. I was recently in Mexico, Haiti and Jamaica. Also was aboard a cruise ship supporting VZW signals. Each time I got a *free* text message from VZW telling me how to dial from where I was (GPS is cool!) to the U.S. They were all different (i.e. 001+10digit, 010+10digit, 1+10digit). Maybe I remembered some wrong, but, the point....
    I have all my numbers entered into my phone with 10 digits (no leading 1s or +s). I made a call from every place to the U.S. Each time all I had to do was to dial using my "People" app just like I always do in the States, and the phone knew exactly how to dial out of where I was, to the States.
    No operator assistance was ever required.
    -Frank
    [HTC Thunderbolt™ 4G/LTE!]
    It's not your dream phone. It's the one after that!©
    Look here for a [VZW Coverage Map] to check your area. Select 4G before hitting [Refresh]
  18. #18
    nate44's Avatar
    Posts
    Global Posts
    813 Global Posts
    ROM
    Synergy
    Quote Originally Posted by FrankXS View Post
    Are you sure?
    -Frank
    Well that may be an outdated definition, as I will take your real world experience over mine any day. If it's on I assume it automatically assists in adding the required prefix needed to make the call.
    In any case if you're not using the phone internationally, there is no need for it to be enabled. Whether or not this has a significant impact on the "dialer drain" is probably not accurate, but any little bit helps!
  19. #19
    Quote Originally Posted by wolf howl View Post
    Those are pretty good results.
    I'm in a strong 4G area and keep it on 4G/WiFi the whole time. It's less hassle for me to simply do a battery swap once a day, than it is to switch back and fourth between 3G/4G 5-9 times a day.
  20. #20
    Quote Originally Posted by TRZ06 View Post
    Menu -> View
    I do the same thing, doesn't help on the stock builds. Not sure what the difference is?? Would've been nice if that fixed it though.
  21. #21
    In "limited" testing, I've found my battery life was much better yesterday (first full day on GB) than it had been in the past. I don't use my phone AT ALL during the day (sits in my car, just receives calls/voice mails/texts/whatever), so I am used to getting about 1.5 hours of active use + 9 hours of idle on a charge. Yesterday easily provided the same 9 hours of idle but closer to 3 hours of active use. (For the record, I only use 3G, and my phone has good signal while it sits in the car).
    Clearly, YMMV, and everyone has different apps and whatever, but at least for me, it was great that I didn't have to put the phone on the charger until I went to bed.
    I wish there was a better battery analyzer that could really pinpoint what was eating my charge.
    -j
    HTC Thunderbolt on Big Red (Stock)
    Logitech Revue Google TV
    Nook Color 1.1 (Auto-nooted)
  22. #22
    i have the same problem with the dialer only way to stop it is a reboot .. if i make zero phone calls the dialer never shows up under battery usage but 1 check of voice mail with set that thing off check battery usage 4-5 hours after making that 30 second voice mail call and dialer will be at 20-30% of bat. usage
  23. #23
    Default
    Quote Originally Posted by jbjonesjr View Post
    I don't know the state you live in but the weather elements are not good for the phone. I don't suggest keeping it in the car. This is a mini computer. Heat and humidity are not good for phones. Just a friendly suggestion. Also it isn't good for the battery.
    sent from my Thunderbolt....and the thunder rolls !
    sent from either my Samsung Galaxy Note2 or my
    Samsung Galaxy Tab 10.1
  24. Thread Author  Thread Author    #24
    biogon's Avatar
    Posts
    Global Posts
    83 Global Posts
    ROM
    Stock
    I wonder if people who have experienced better battery life accordingly have not used the phone/dialer aspect since a reboot.
    I know that yesterday my battery was about 30% when it should be 50% after about 16 hours, and that the Dialer was reported to take up nearly 40% of my battery time.
    I have reinstalled PowerTutor and will see whether it will provide useful data.
  25. #25
    i do get better battery life than before i can go almost 3 days on extended if i dont dial a thing.. but after making one call it with screw that up..got to be a way to stop the dialer without having to reboot......when the dialer is up under batt. usage and u click on it 5 other things show up i wonder if those are just apps that can access the dialer or ones that are actually running at the moment
