Non Rooted only stock Thunderbolt....Ever since the last ota update (the one after the GB update) my weather on the home screen shows a different town ( like 180 miles away). If I try to add my town it does not show on the list of available towns. If I open Maps it starts in my location, goes to the other city for a few moments then returns to the correct location. Tried Beweather and it works correctly. Any ideas ??
Thanks
I remember this happening to me even prior to GB. Including how Google Maps behaved as far as opening in my location, going to another city, then quickly moving back to my location. I think it was my last Google Maps update that fixed it. I have version 5.11.0 now. What version to you have?
Also, for weather, you might to make sure you have no other cities configured. Just let it use "my location". Occasionally, when the weather station cannot be reached, or is temporarily down (it happens) you might see a foreign city. But not routinely. Your profile says Ruidoso NM, I think that should be listed. I believe the Sense weather widget uses the Accuweather service. Accuweather certainly lists Ruidoso. I dunno...
If it matters, I keep all my location services enabled (i.e. GPS, Google, VZW) all the time.
-Frank
