Results 1 to 3 of 3
    Default Unrooting Thunderbolt Revolutonary Wont Recognize Phone HELP
    So Im Getting A Replacement Because Im Always Loosing Data
    And Im Trying To Unroot My Thunderbolt With Revolutionary (Rooted With Revolutionary)
    And Im Stuck At The Command Prompt Where Its Supposed To Recognize My Device And My Serial And It Wont
    I Tried With My Thunderbolt Connected As DISK DRIVE And Also As CHARGE ONLYAND NOTHING WORKS
    PLEASE HELP IM REALLY FREAKING OUT I WONT BE ABLE TO UNROOT MY THUNDERBOLT
    Attached Thumbnails Attached Thumbnails Unrooting Thunderbolt Revolutonary Wont Recognize Phone HELP-rooting.jpg
  2. #2
    trter10-imore's Avatar
    ThunderboltTool Developer
    Posts
    ROM
    Liquid JB v2.1 Alpha6
    Default Re: Unrooting Thunderbolt Revolutonary Wont Recognize Phone HELP
    Enable usb debugging.
    Also, you can just use my Unroot tool found here Thunderbolt Auto-Unrooter
    Thank You I Found The Problem And Did Unroot It
