Results 1 to 3 of 3
    jhimebau's Avatar
    Posts
    Global Posts
    62 Global Posts
    Default Playing audio through headphone jack; using bluetooth
    I am rooted and running a custom ROM named Liquid Smooth Nonsense. I have run all of the Liquid Smooth custom ROMs. I have tried most of the versions of BAMF and I have run Sky Raider and others.
    The only ROMs I have found to allow me to play audio books into my car stereo and use the bluetooth speaker phone at the same time is the stock and rooted ROMs from HTC leaks.
    Do I have something configured wrong?
    Does anyone else have this problem?
    Thanks.
  2. #2
    Default Re: Playing audio through headphone jack; using bluetooth
    i kinda do same. go to bluetooth settings. on each device click and hold until menu appear, the you can check media or phone audio to either device.i've run all kinds of roms and set headset to phone audio, media to laptop and works for me.but i'm using 2 bluetooth conections. you should be able to line out to car and bluetooth for calls.
  3. #3
    JVH1982's Avatar
    Posts
    ROM
    Stock
    I'm stock, and had a similar issue. It resolved itself after a restart. It seemed to be confused for that particular car ride.
